Biscuits vs. Hardboard Splines
Forum topic by dvhart posted 08-15-2010 02:16 AM 3394 views 0 times favorited 17 replies Add to Favorites Watch
View dvhart's profile
dvhart
111 posts in 3012 days
08-15-2010 02:16 AM
I’m preparing to build a sewing desk/cabinet for my wife. The plans call for a hardboard spline to attach a hardwood edge to each side of the various table panels. I’ve been using biscuits for my cabinet construction and am comfortable with them and already have the tools/accessories needed to use them. Will biscuits spaced every 6” provide adequate alignment and strength, or should I stick to the spline in the plan?
-- Darren
17 replies so far
View ABrown's profile
ABrown
102 posts in 2908 days
#1 posted 08-15-2010 02:30 AM
The biscuits should do just fine, I myself have grown quite attached to pocket holes and screws if it’s in a area where it isn’t seen.
View Moron's profile
Moron
5032 posts in 3890 days
#2 posted 08-15-2010 02:39 AM
biscuts will work just fine
View Dark_Lightning's profile
Dark_Lightning
3159 posts in 3106 days
#3 posted 08-15-2010 03:18 AM
The spline is like “belts and suspenders” as we say at work. Either one would hold your trousers up, but you’re guaranteed they won’t fall if you use both. You can rout for the spline with a slotting bit, if you really want to do that, but it really isn’t necessary…unless someone REALLY leans on that sewing table. I’m thinking the material doesn’t weigh that much.
-- Random Orbital Nailer
dvhart
#4 posted 08-15-2010 03:53 AM
Thanks guys. My thought was that the spline might do a better job with alignment during the glue up stage and possibly reduce the amount of scraping/sanding I have to do. I’m not terribly concerned about strength as I have a lot of confidence in the biscuits.
-- Darren
View Lee Barker's profile
Lee Barker
2170 posts in 2847 days
#5 posted 08-15-2010 04:02 AM
What are the “table panels”? Plywood?
Assuming you were on the proverbial desert island without the Interwebs, you’d try all three on scrap, let them cure, and then see what it takes to break them. I think you might be surprised how well glue works without added stuff.
View jusfine's profile
jusfine
2422 posts in 2923 days
#6 posted 08-15-2010 04:27 AM
I like biscuits (and gravy)...
-- Randy "You are judged as much by the questions you ask as the answers you give..."
dvhart
#7 posted 08-15-2010 04:30 AM
@Lee: The panels are 3/4” cherry veneer plywood. And I agree about a proper glue joint. As I said above, I’m concerned about the relative effectiveness of the alignment each method provides. I think either will be plenty strong.
-- Darren
Beginningwoodworker
13345 posts in 3670 days
#8 posted 08-15-2010 04:40 AM
Biscuits will be good enough.
Lee Barker
#9 posted 08-15-2010 07:47 PM
Thanks for the additional info, Darren. Would it be easier to align if you used just glue, no mechanical alignment technique like splines or biscuits?
dvhart
#10 posted 08-15-2010 09:42 PM
In my experience, there is always some variation in natural materials. The spline and the biscuits help adjust for that in the joint, rather than in clamping techniques. I find it easier to use some sort of alignment mechanism for these applications.
-- Darren
View tnwood's profile
tnwood
258 posts in 3083 days
#11 posted 08-15-2010 10:22 PM
If you look at the Project I just posted you will see a sewing machine cabinet I just finished; probably from the same plan you are using. I used biscuits about every foot. It isn’t going anywhere.
Lee Barker
#12 posted 08-15-2010 10:40 PM
Thanks tnwood; that helps me understand the issue. I think biscuits are a good choice here, given the width of the solid stock edging. I was thinking it was much smaller than that.
My experience in general is that splines particularly, and biscuits occasionally, don’t give me the precision I want (and I use a Lamello Top 20) in aligning two surfaces. Using just a glue joint, and walking the clamping out from the center, usually does.
View richgreer's profile
richgreer
4541 posts in 3071 days
#13 posted 08-15-2010 10:49 PM
If you do a good job of gluing and clamping, you probably don’t need biscuits or splines. However, I find biscuits can help with alignment. Splines will also, but biscuits are usually easier.
dvhart
#14 posted 08-16-2010 12:08 AM
@tnwood: indeed, it is the same plan (yours turned out beautiful btw).
All, thanks for the thoughts and comments, biscuits it is – and I’ll shoot for every 12 instead of every 6 per tnwood’s example – should make the glue up all that much easier.
-- Darren
tnwood
#15 posted 08-16-2010 02:40 PM
While I do use biscuits for alignment purposes, I also sometimes have difficulty with getting them properly in place. I have an old Porter Cable biscuit cutter that isn’t very stable. The good thing is that when something gets mis-cut it is hidden and I can leave the biscuit out or fill the bad cut and recut it. I’m not a big fan of these things but occasionally they help with alignment but I don’t think they contribute much to strength. For the most part I just get a good glue joint fit and adjust things as I glue up in the clamps.
