Much ado about a chisel
« back to Hand Tools forum
Forum topic by Marn64 posted 12-23-2016 07:32 PM 517 views 0 times favorited 2 replies Add to Favorites Watch
View Marn64's profile
Marn64
295 posts in 807 days
12-23-2016 07:32 PM
Topic tags/keywords: question chisel refurbishing
Hey everyone,
So I recently found this old socket chisel that was clearly at one point a bench chisel but after 150 or more years of wear it has made itself about 5 1/4 inches in length from socket to bevel. I found it with a set of antique Witherby chisels and this clearly wasn’t part of that set and it was much older than them, but I felt bad for it so I bought it and decided to convert it into a butt chisel! Here it is before I started any major lapping. Have any of you ever done this with chisels that have worn away with sharpening and use?
Here’s it after some lapping with 120 grit sandpaper, I haven’t gotten to any higher grits yet but I have a feeling that I am close.
Here’s a spot that I feel like I should lap out. Should I do that with 120 or ignore it and move up in grits?
-- Benjamin, Milwaukee
2 replies so far
View Loren's profile
10476 posts in 3669 days
#1 posted 12-23-2016 07:40 PM
I would lap it out now. If you don’t it will
likely cause problems later.
View EricTwice's profile
EricTwice
237 posts in 555 days
#2 posted 12-23-2016 07:44 PM
Personally I think if the edge is clean you should stop. When it wears down to the point your rust becomes a nick in the blade, take some more off the back. Taking more off the back now will shorten the blade for no good reason.
Just my opinion
-- nice recovery, They should pay extra for that mistake, Eric E.
