Sanding mats
Forum topic by xeddog posted 12-22-2016 10:51 PM 1510 views 0 times favorited 18 replies Add to Favorites Watch
View xeddog's profile
xeddog
205 posts in 3155 days
12-22-2016 10:51 PM
I am referring to those rubber, or other material, mats used to put on your bench that keep workpieces that are being sanded from running all over the table top. All of my work surfaces are covered with Formica, and so far I have not found anything that works. I have tried several of those perforated rubber mats, solid rubber, fiber mats, and probably somethings I have forgotten. But they all make things worse. I have a lot less chasing to do when I just put the wood onto the Formica surface and go to town on it.
What, if anything, do you use to keep your workpieces from running around on your tables?
Wayne
18 replies so far
View JoeinGa's profile
JoeinGa
7739 posts in 2155 days
#1 posted 12-22-2016 10:55 PM
I bought a roll of this rubber mesh shelf liner from WallyWorld 4 or 5 years ago. It works pretty good for me. And I’ve only used about 1/3 of the roll.
View eflanders's profile
eflanders
310 posts in 1999 days
#2 posted 12-22-2016 11:16 PM
I use the same as JoeinGa.
View MrUnix's profile
MrUnix
6948 posts in 2347 days
#3 posted 12-22-2016 11:19 PM
That stuff Joe pointed out does work well… and you can get it just about anywhere for pretty cheap. But it can be torn up fairly easily if you aren’t careful. Try looking around next time you are at the BORG… as drawer and shelf liner material. Some free options are: Treadmill belts, old rubber mouse pads and old rubber door mats. The treadmill option will also land you a nice variable speed DC motor, power supply and controller that you can re-purpose for lots of other stuff. It also gets you a ton of hardware and metal tubing.
View oldwood's profile
oldwood
155 posts in 1392 days
#4 posted 12-22-2016 11:37 PM
I don’t have formica work surfaces but the best thing I have found is carpet padding. Find it on the curb waiting for garbage collection.
View clin's profile
clin
929 posts in 1144 days
#5 posted 12-22-2016 11:41 PM
I use the shelf liner Joe mentioned. But, I do rinse it after using. Once it gets a lot of dust on it, it still gets slick when I happen to being using it on a melamine topped outfeed table I occasionally use for sanding.
Formica is slick like melamine and I don’t think there is anything that won’t slide on it once you get some dust under it.
What about a temporary work surface. Like a large board with something non-slick on it that you can clamp to your Formica topped bench? Just thinking out loud.
-- Clin
MrUnix
#6 posted 12-22-2016 11:44 PM
I don t have formica work surfaces but the best thing I have found is carpet padding. Find it on the curb waiting for garbage collection.
- oldwood
Dang, I forgot about that stuff.. and I have a couple of rolls of it out in the shed! It does work well, and you can use it for all sorts of useful things. If you can’t find it on the side of the road after an install, if you have any new home construction around you, you can get all you would ever need for several lifetimes.
View BurlyBob's profile
BurlyBob
5918 posts in 2414 days
#7 posted 12-23-2016 01:53 AM
I’ve got both the carpet pad and shelf liner. They both work great!
View DirtyMike's profile
DirtyMike
637 posts in 1050 days
#8 posted 12-23-2016 02:01 AM
I have been using a piece of the puzzle piece anti fatigue floor mat. super grippy and tough.
View papadan's profile
papadan
3584 posts in 3517 days
#9 posted 12-23-2016 02:13 AM
I drilled some small holes and just drop in dowel pieces to stop anything from sliding when routing or sanding.
xeddog
#10 posted 12-23-2016 03:51 AM
JoeinGA – I’ve tried several of that type of mat. Light Brown, Dark Brown, Black . . . But I will have to look for the blue stuff. :-)
MrUnix – I have tried stuff called shelf liner, drawer liner, toolbox liner, and even some stuff sold as a sanding mat by (I think) Rockler. It all just makes things worse. But treadmill belts??? Hmmmm.
oldwood – carpet padding!!! I think I even have a small piece of that laying around that I can try.
DirtyMike – I have some of those puzzle piece mats on my shop floor. But there are different grades of those mats from really lightweight cheap crap (like my HF stuff) to more expensive not cheap crap. I also have one of those other solid cushions that I might try.
papadan – I’m not ready to drill holes in my counter/table tops.
Thanks for the input
Wayne
JoeinGa
#11 posted 12-23-2016 12:39 PM
Wayne:
If you’ve tried several different colors of the mesh shelf liner and are not happy with it, dont bother looking for the blue. It’s all pretty much the same stuff. The picture I posted is one I found in a Google image search and it showed the mesh.
But the actual reason I’m responding again is about the folks that pick up carpet padding from the curb … I certainly hope you make sure the reason your neighbors pulled up the old carpet and padding ISNT because they have dogs in the house. That old padding could stink up your shop something horrible !
View JBrow's profile
JBrow
1366 posts in 1068 days
#12 posted 12-23-2016 03:03 PM
xeddog,
I really like clin’s idea of a separate sanding work surface that sets atop the work bench. It could be a piece of MDF (for its flatness) cut the width of the workbench. A pair of cleats like those on a bench hook (but both cleats mounted under the MDF surface) could lock the auxiliary sanding surface to the two long edges of the workbench. A solid router mat glued to the MDF with contact cement would provide a soft work surface for sanding. The sanding surface could be clamped on one end to keep it from sliding along the length of the workbench or a alignment hole could be drilled through a cleat that is attached to the sanding surface for a dowel that would slip through this hole and catch a mating hole drilled into the edge of the workbench.
The only problem I can foresee with this solution is that the sanding surface must be stored when not in use.
View splintergroup's profile
splintergroup
2313 posts in 1371 days
#13 posted 12-23-2016 03:41 PM
As stated, what ever you use will begin to slip when dusty.
For a while I used the matting JoeInGa shows, works great except it begins to slide around when dusty. I used spray adhesive (3M “77”) and sprayed a piece of 3/4” melamine, waited a minute, then placed the matting on top. Works well! Alternatively I have used door mats. They have the mass to keep from moving and bunching up. You just need to find the right material so your project won’t slide on the surface (and you still need to wipe off the dust on occasion.
What is great about the matting is it has the holes so if you spray-glue it down to a piece of perforated masonite (used for those metal hanger hooks), it makes the beginning of a fine sanding box. You add a chamber box underneath for a dust vacuum, The matting has the holes to allow the dust to flow through. A sanding “station” is great to have if you have a dust collector and the space.
View OnhillWW's profile
OnhillWW
137 posts in 1380 days
#14 posted 12-23-2016 04:08 PM
I happened onto bulk runner carpet at the local BORG. It has rubber backing and tight nylon indoor outdoor type woven top. Buy it by the foot. I purchased a 10 foot length and cut sections as needed. Rubber side down stays in place and provides protection for workpieces that are in the final stages of preparation. Carpet side down, secured to my work top via clamps keeps pieces in place for sanding. I keep a hierarchy of these as they wear or collect contaminants and they see duty for gluing or finishing etc. I have tried rubber pucks, drawer liners etc and find I prefer these but YMMV. Worth a shot as they are very inexpensive and pretty darn durable.
-- Cheap is expensive! - my Dad
xeddog
#15 posted 12-23-2016 05:49 PM
... I certainly hope you make sure the reason your neighbors pulled up the old carpet and padding ISNT because they have dogs in the house. That old padding could stink up your shop something horrible !
- JoeinGa
EEEEWWWWW!!!!! And the stink would only be half of it. EW! EW! EW!
xeddog,
- JBrow
I would LOVE to have a downdraft table, but my garage workshop is already over-crowded.
... Alternatively I have used door mats.
- splintergroup
Interesing.
- OnhillWW
Also interesting.
Y’all have given me several alteratives that I can look into, Thanks evertone,
Wayne
