Routing problems
« back to Coffee Lounge forum
Forum topic by Edwin posted 08-14-2010 06:00 PM 1935 views 0 times favorited 10 replies Add to Favorites Watch
View Edwin's profile
136 posts in 2927 days
08-14-2010 06:00 PM
Ive been making some oval picture frames from wood magazine. I glued up five piece of wood 1 1/4” wide the center piece is pine than the next two pieces on each of the pine are black walnut, than I glued two pieces of oak to the outside. I than proceeded to cut an oval 6 5/8” tall by 5 1/8” wide. The center also has an oval cut out which is 4” tall by 2 1/2” wide than on the inside oval you rout a 1/4” cove. My problemis is this I got burn marks on the pine and oak. How do I remove the burn marks without taking away the sharp lines that the router created.
Thanks for any info. Ed
-- Ed Port Republic
10 replies so far
View richgreer's profile
4541 posts in 3004 days
#1 posted 08-14-2010 06:10 PM
The best idea is to not get burn marks in the first place. Often, burn marks are due to a less than perfectly sharp bit. Make certain your bit is sharp.
Also – Make sure you keep the router moving and don’t take off too much in any one pass.
#2 posted 08-14-2010 06:21 PM
Hi Rich, I was going very slow and had such a shallow cut and the bit was brand new. I had to take the parafin wax off before i used it. Now i’m really scratching my head ?? Thanks Ed
-- Ed Port Republic
View ajosephg's profile
1880 posts in 3490 days
#3 posted 08-14-2010 08:03 PM
You may have been going too slow. There’s a happy balance betwee too slow and too fast. Too slow causes burning, too fast bogs the router or causes you to lose control of the cut.
-- Joe
#4 posted 08-14-2010 08:06 PM
Let me also comment that a new bit is not necessarily a sharp bit. I’ve often had to sharpen a new bit before using it.
18224 posts in 3605 days
#5 posted 08-14-2010 08:09 PM
I had that problem going too slow when I first started routing. Took a long time to figure it out. No internet in the 70s :-))
6850 posts in 3909 days
#6 posted 08-14-2010 09:39 PM
Hi Ed;
To remove burn marks, spray the burn marks with mineral spirits, then sand them carefully.
The mineral spirits makes burns much easier to remove.
-- by Lee A. Jesberger
View Gene Howe's profile
Gene Howe
10240 posts in 3358 days
#7 posted 08-15-2010 12:33 AM
Lee has the idea. I’ve also used lacquer thinner with quicker results. i.e less sanding. A lot will come away with a rag. Wet sand the rest.
View AaronK's profile
1505 posts in 3394 days
#8 posted 08-15-2010 01:15 AM
not sure exactly of the overall design/profiles you’re describing, but a curved card scraper sharpened up nice might help as well.
View Sawdust4Blood's profile
400 posts in 2951 days
#9 posted 08-15-2010 01:59 AM
Like Aaron, my first choice for burn marks is a scraper when possible. If you have a very fine adjustment on your router depth, you can also expose just a skosh more of the bit and run the router over for another quick pass. As others have suggested, you might be routing too slow or you might try slowing the rotation speed. As Rich suggested all but the best quality bits can usually stand a little honing even when they are brand new. Pitchy woods (like pine) will always burn more/faster than others and will require cleaning the bits more frequently.
-- Greg, Severn MD
View jusfine's profile
2422 posts in 2855 days
#10 posted 08-15-2010 04:24 AM
Greg, you beat me to the solution I thought of.
I would also try taking just a hair (or a skosh) more and that should clean it up.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
