screws or bolts
Forum topic by Jim K posted 08-14-2010 06:41 AM 860 views 0 times favorited 3 replies Add to Favorites Watch
View Jim K's profile
Jim K
94 posts in 3133 days
08-14-2010 06:41 AM
Hi all
I’m going to add an incra jig to my router table that has mdf covered malamine. What do i use screws or bolts? If i use screws what kind would everyone think would be best to use?
Thanks Jim K.
3 replies so far
View richgreer's profile
richgreer
4541 posts in 3070 days
#1 posted 08-14-2010 02:33 PM
If you have easy access to the underside of the table, I would use bolts with the nuts and washers on the underside. Screws might be sufficient. You KNOW the bolts will be.
Jim K
#2 posted 08-14-2010 02:56 PM
Thanks rich
I can get to the underside. I’m going with 1/4×20 bolts with fender washers too.
Jim K.
richgreer
#3 posted 08-14-2010 04:53 PM
I’d advise a locking washer with the fender washer, a friction nut (with the plastic inserts) or some titebond.
The vibration from the router could cause the nuts to come loose otherwise.
