Best 6" or 8" jointer?
Forum topic by Rykr posted 12-21-2016 10:30 PM 858 views 0 times favorited 19 replies Add to Favorites Watch
View Rykr's profile
Rykr
6 posts in 549 days
12-21-2016 10:30 PM
In the market for a good floor 6” or 8” jointer. Any suggestions? Was kind of looking at this guy – http://www.grizzly.com/products/6-Jointer-with-Knock-Down-Stand/G0813?utm_campaign=zPage&utm_source=grizzly.com.
What do you guys think?
19 replies so far
View Andre's profile
Andre
1888 posts in 1834 days
#1 posted 12-21-2016 11:58 PM
I picked up an Laguna 6” helical head jointer and General 12.5 ” planner a couple of years ago and now wish jointer was at least 8” or bigger, seriously thinking going the combo route, maybe 16” if possible? Minimum 12”!
View Gaffneylumber's profile
Gaffneylumber
102 posts in 856 days
#2 posted 12-22-2016 12:48 AM
Better to have and not need than to need and not have. Go for the 8”.
-- Grayson - South Carolina
View RogR's profile
RogR
110 posts in 893 days
#3 posted 12-22-2016 01:30 AM
If you are mostly doing small work (say, cabinets) the 6” might work out. The long bed of the 8” is a real boon if you get into longer stock (tables, doors etc). Solid machines, but sporadic reports of fence flatness issues suggest you should check yours carefully prior to assembly.
View Rykr's profile
Rykr
6 posts in 549 days
#4 posted 12-22-2016 01:57 AM
Any thoughts on certain makes? Jet? Grizzly? Shopfox?
View CharlesA's profile
CharlesA
3329 posts in 1825 days
#5 posted 12-22-2016 02:05 AM
Grizzly and Shopfox are the same company. Usually corresponding models.
View knotscott's profile
knotscott
8057 posts in 3403 days
#6 posted 12-22-2016 02:19 AM
If you’re even remotely pondering an 8 inch, grab it. So long as it does the basics well enough, capacity matters more than features for most wwers.
View TheFridge's profile
TheFridge
9608 posts in 1514 days
#7 posted 12-22-2016 02:36 AM
8” definitely.
CharlesA
#8 posted 12-22-2016 02:39 AM
I assume you already know that almost all 8”’jointers are 240, almost all 6” can be run on 120.
View Rykr's profile
Rykr
6 posts in 549 days
#9 posted 12-22-2016 02:39 AM
ok, sold on the 8”. now I’m trying to decide spiral cutter head or traditional. spiral or helical are typically much more expensive.
View Rykr's profile
Rykr
6 posts in 549 days
#10 posted 12-22-2016 02:40 AM
I assume you already know that almost all 8” jointers are 240, almost all 6” can be run on 120.
- CharlesA
Right. Saw that. I typically will edge join so a 6” with an extra long infeed would be ideal.
View Rykr's profile
Rykr
6 posts in 549 days
#11 posted 12-22-2016 02:42 AM
8” with spiral cutter heads are at least $1200 (Grizzly) and higher so may have to start small with either benchtop or 6”. Funds not unlimited and not a pro :)
knotscott
#12 posted 12-22-2016 03:18 AM
- CharlesA
- Rykr
What will you do to flatten a reference face?
TheFridge
#13 posted 12-22-2016 03:26 AM
If you can get an 8” with straight knives you can always upgrade later because the helical head is worth every penny to me. I just got sick and tired of setting knives and adjusting. Plus it cuts like butta.
View MrUnix's profile
MrUnix
6768 posts in 2227 days
#14 posted 12-22-2016 03:31 AM
A 6” jointer is just as good as an 8” one if all you ever use is 4” wide stock :)
Depends on what you do… and how much space you have… and what kind of electrical service is available… and how mobile you need it to be… and…
View Rykr's profile
Rykr
6 posts in 549 days
#15 posted 12-22-2016 03:56 AM
- CharlesA
- Rykr
- knotscott
I’m not a pro woodworker by any stretch but what I have done in the past is put my rough stock through my planer until I had each side the way i wanted it and then straighten the edge through the jointer. This leaves me with square and smooth material to work with.
