Need advice for cutting a very thick slab
Forum topic by jjagerson posted 08-13-2010 12:00 AM 1166 views 0 times favorited 8 replies Add to Favorites Watch
View jjagerson's profile
jjagerson
42 posts in 2846 days
08-13-2010 12:00 AM
I have a very thick slab of 4 laminated sheets of plywood and MDF (making a benchtop core). The sides are cut pretty square because I cut everything as single sheets before gluing it together but it is still slightly out of square now that it is one piece. HOWEVER, I don’t dare cut it on my table saw because I can’t get either of the two sides flat first to ride against the fence and it is very, very heavy (about 140lbs). I can’t cut it with my circular saw because it is 3” thick and I have only 2.5” of clearance with that tool. I also took a stab at it with my scrub plan but that MDF is a mess. I thought about using a flush trim bit in my hand held router but that is the only idea I have remaining that I havening tried. I even experimented a little with a long jigsaw blade but it gets about .5” into a test piece and just jams up.
Any ideas?
8 replies so far
View DrDirt's profile
DrDirt
4418 posts in 3611 days
#1 posted 08-13-2010 12:07 AM
Assuming you have the space to run the full width and support. You can tack a strip on the ‘Bottom’ sheet edge so that it sticks out say 1/2 inch, like a little outrigger. This piece would run against your fence giving you that first straight cut. Then when you rotated 180 degrees you would have that first flat face.
Good luck
jjagerson
#2 posted 08-13-2010 12:09 AM
Dave! That is a great idea!
Thanks
View Raftermonkey's profile
Raftermonkey
560 posts in 2781 days
#3 posted 08-13-2010 12:15 AM
DING, DING, DING!!!! We have a winner!!!haha. Great solution Dave.
-- -Zeke- "I hate to rush off, but I gotta go see a man about a log"
View richgreer's profile
richgreer
4541 posts in 2943 days
#4 posted 08-13-2010 12:30 AM
Dave got it right and shopguryl added an important refinement.
You should never cut more than about 1.5” in a single pass with a TS.
jjagerson
#5 posted 08-13-2010 01:23 AM
Ahhhh that does make a lot of sense – thanks! I will do it tonight and let you know how it goes.
Thanks a ton everyone!
View swirt's profile
swirt
2504 posts in 2841 days
#6 posted 08-13-2010 04:25 AM
Just in case it is too heavy to wrestle it onto your table saw, clamp a straight edge to it with enough width for the shoe on your circular saw. Make as deep a cut as it will handle, then flip it over and use a bottom bearing flush trim bit, or use a hand saw inside the kerf left by the circular saw.
View paratrooper34's profile
paratrooper34
915 posts in 2821 days
#7 posted 08-13-2010 05:11 AM
Personally, I would stay away from trying to manuever a 140 lb item through a spinning blade. Seems dangerous to me. I would try to find a way to make the cuts with a circular saw and/or a hand saw. Those two methods reduce risk to you and the piece.
Good Luck!
-- Mike
jjagerson
#8 posted 08-13-2010 06:22 AM
Thanks you all for the great advice. After setting up some supports to attempt the first idea on my table saw (a ridgid contractors saw, not a nice cabinet saw or something) I decided it was going to be too difficult to maneuver the piece and still keep me and the saw safe. – I think you were probably right, paratrooper34. I probably should have mentioned in the first place that I don’t have a big saw.
So I modified the ideas just a bit. I did rip a nice straight piece that I tacked to the surface of the core that my circular saw could ride against. I did that rather than clamping down a saw guide because the core is almost 8’ long and since this is just the core of the top, a couple nail holes won’t really matter in the least. Thanks, Dave & Shopguryl for the idea in the first place.
I did take your advice, Rich and I kept the blade reasonably low. I flipped the top over and did the same thing after measuring very very carefully and wound up with an extremely small bump down the middle of the side that I was able to scrape right off. Everything came out nice and straight. I then squared the two short sides in the same fashion.
This was one of the things i have been sitting on to finish the bench so I will post a picture when I am done. I think it will look very nice.
