Asking Toys and Joys truck builders
Forum topic by Dee1 posted 12-20-2016 12:49 AM 1189 views 0 times favorited 16 replies Add to Favorites Watch
View Dee1's profile
Dee1
301 posts in 2066 days
12-20-2016 12:49 AM
Hi guys and gals
I am currently building the Truck and low bed trailer, and I must ask for some help or suggestions
I am trying to glue the trailer floor to the deck over the rear wheels.
the angle cut is 21.5 on the two joints and I have been so far unable to figure out how to clamp them together to get a good solid glue joint>
Thanks for any help with this I tried sever old tricks but none have worked yet?
16 replies so far
View JAAune's profile
JAAune
1846 posts in 2494 days
#1 posted 12-20-2016 01:49 AM
Use angled cauls like those shown in the picture below. There are various ways to achieve this. You can glue the cauls to plywood then clamp the plywood to the workpiece. It’s also possible to glue them right to your project with PVA and a piece of paper between the caul and the wood. The paper allows the parts to be separated easily.
View tealetm's profile
tealetm
102 posts in 1035 days
#2 posted 12-20-2016 02:37 AM
Have you tried tape?
View LittleBlackDuck's profile
LittleBlackDuck
2050 posts in 998 days
#3 posted 12-20-2016 03:44 AM
- tealetm
tealetm has it all taped up. I have found that for most mitre joints a good dose of tape (blue tape not duct) will seal the deal. If you need strength in the joint try, re-enforcing with dowels or splines (even slivers will do). Even a 1/16” or 1/8” dowel does wonders.
PS. Nice looking cab!!!....
View crowie's profile
crowie
2693 posts in 2128 days
#4 posted 12-20-2016 08:43 AM
Just a thought…would you be able to biscuit join those pieces????
-- Lifes good, Enjoy each new day...... Cheers from "On Top DownUnder" Crowie
View Dutchy's profile
Dutchy
3126 posts in 2346 days
#5 posted 12-20-2016 12:20 PM
View gwilki's profile
gwilki
226 posts in 1651 days
#6 posted 12-20-2016 02:43 PM
Funny you should ask. I built that same model and a dump truck a couple of years ago. To “clamp” those joints, I just put a couple of dabs of CA glue at the ends of the pieces. Then, I spread the PVA glue between those dots. When I pushed the together, the CA set in 10 seconds and held the joint in place until the PVA added the stronger joint that I wanted. I’ve used this method several times now for tricky joints and it’s always worked well.
-- Grant Wilkinson, Ottawa ON
View DS's profile
DS
3025 posts in 2598 days
#7 posted 12-20-2016 02:50 PM
If you are building up your tool set, these are really handy.
Mine don’t see a lot of action, but when they do, they are invaluable.
View Dee1's profile
Dee1
#8 posted 12-20-2016 04:11 PM
Hey this is a great forum what a great bunch of responses
I have never used the blue tape, and I tries it and I think we have a winner. thank all you guys all great ideas.
Thanks again
Dee
LittleBlackDuck
#9 posted 12-20-2016 04:41 PM
I have never used the blue tape, ....
- Dee1
Just don’t be too stingy with the blue tape… especially on the underside (not like I have tried to draw)...
Lay the tape sticky side up (unless you want to stick your bench)... but the mitre ends together (flat)... add glue… draw mitre joint together… secure/tigten with blue tape on the other side (preferably “loosely” placed before glue up… and pulling the joint together)....
Just watch out for sharp edges that may cut the tape if pulling TOO tight. It is quite surprising the pressure you can apply (within reason).
View GR8HUNTER's profile
GR8HUNTER
4936 posts in 890 days
#10 posted 12-20-2016 04:57 PM
I also had the same question here all my responses I got back
http://lumberjocks.com/topics/167810
crowie
#11 posted 12-20-2016 11:31 PM
Mine don t see a lot of action, but when they do, they are invaluable.
- DS
What brand are they and Were did they come from please “DS” .... thank you
View htl's profile
htl
4202 posts in 1337 days
#12 posted 12-21-2016 12:15 AM
Funny you should ask. I built that same model and a dump truck a couple of years ago. To “clamp” those joints, I just put a couple of dabs of CA glue at the ends of the pieces. Then, I spread the PVA glue between those dots. When I pushed the together, the CA set in 10 seconds and held the joint in place until the PVA added the stronger joint that I wanted. I ve used this method several times now for tricky joints and it s always worked well.
- gwilki
gwilki I’ve been using this trick more and more on my builds to add strength [wood glue] and speed [super glue] it’s a winning combination.. *And after it was dry I still drilled it for two small dowels just to be safe, mine has a split track so felt like it might need it.. *
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
View Lazyman's profile
Lazyman
2561 posts in 1565 days
#13 posted 12-21-2016 03:03 AM
How about a pair custom corner clamp that are made from scraps to hold the 2 pieces at the correct angle. See this video by Izzy Swan to see what I mean. Yours would be made for the angles of you project rather than 90 degrees of course. It doesn’t have to be as elaborate or reusable as his but you just need one on both sides to hold them at the correct angle while you apply pressure to the glue joint. I you add a block to the clamp you may also be able to use a regular F clamp to apply a little pressure.
I would also add a spline to the joints. Gluing end grain to end grain will not hold very well no matter how perfect you are able to clamp it and a spline will give you side grain glue surfaces to greatly increase the strength of the joint. The spline will also make it so it is less likely to slide apart while clamping it.
Nice work by the way.
View DS's profile
DS
#14 posted 12-21-2016 06:29 PM
Crowie, now you’re making me scratch my head as to where I got mine from. I think I found them on Amazon for a discounted price.
The image I posted was from Woodcraft and is a bit more money.
crowie
#15 posted 12-21-2016 09:49 PM
Crowie, now you re making me scratch my head as to where I got mine from. I think I found them on Amazon for a discounted price.
- DS
Thank you sir..
Hopefully no splinters just sawdust..
Happy Christmas from the Great Southern Land…
