Jamb saw recommendations?
Forum topic by scott_v posted 08-12-2010 03:14 PM 1408 views 0 times favorited 5 replies Add to Favorites Watch
View scott_v's profile
scott_v
13 posts in 3255 days
08-12-2010 03:14 PM
I’m shopping for a good powered jamb saw. Any recommendations?
5 replies so far
View Marco Cecala's profile
Marco Cecala
189 posts in 4149 days
#1 posted 08-12-2010 03:29 PM
When I installed floors for a living, Crain was the go to saw.
If you need a few doors, you can tape some quarters to the bottom of a piece of flooring. This makes space for thinset or foam. Use a recip saw with a long blade that can flex to conform to the material.
27250 posts in 3938 days
#2 posted 08-12-2010 04:27 PM
Scott, I have found the Dremel MultiMax a pretty good tool for this application. It only cuts 3/4” at a time but it cuts out door jams for flooring pretty quickly. I would not use this if I were going to install flooring routinely but, if you are going to do just a few rooms, it might be something you would be interested in looking at. It is available at Lowe’s, Wal-Mart, etc. and costs right at $100.
View mnguy's profile
mnguy
193 posts in 3514 days
#3 posted 08-12-2010 07:51 PM
A Japanese pull saw with a scrap of flooring or other shim /guide will also do the trick if you only have a few to do. Flex the blade to conform to the shim. A cheaper version like the Irwin at HD would be adequate.
View polyhedron's profile
polyhedron
18 posts in 2961 days
#4 posted 08-12-2010 09:52 PM
I recommend a Jamb saw only if you do a lot of jambs.
Otherwise, get a great multipurpose tool that does a great job in almost the same fashion.
Multimaster or
Sonicrafter or
MultiMax
Take your pick, those are all great tools for that.
-- Matt, The Cabinet Bumper Store - http://www.AnyBumper.com - Use Promo Code: LJ2017 for 10% OFF
View DaveDelo's profile
DaveDelo
86 posts in 3010 days
#5 posted 08-12-2010 11:14 PM
I’ve been seaching on CL for a used Crain for over a year without success until the other day. Got a used 800 model for 60 bucks. Works great and couldn’t be happier.
For the wooodwork (4rooms + 2 pocket doors) I need to cut, I see no other way to do the job other than using a crain or roberts tool. Tried the MultiMax and also a Bosch power hand saw. Zero success. Tools smoked up big time within 2 seconds. I can cut softwood with my little gizmos but the hard stuff is out of the question.
