Has anyone modified a belt speed lathe into a variable speed lathe?
Forum topic by tooldad posted 08-12-2010 04:33 AM 959 views 0 times favorited 2 replies Add to Favorites Watch
View tooldad's profile
660 posts in 3647 days
08-12-2010 04:33 AM
I know they make kits, however with a router, I simply used a standard 110v dimmer switch, and it works fine. Does anyone see a problem doing this with a small benchtop lathe?
2 replies so far
View richgreer's profile
4541 posts in 3007 days
#1 posted 08-12-2010 04:41 AM
I’m not an expert on this, but I raised the question about running my lathe on something like a dimmer switch to make it variable speed. There are variable speed switches designed to power routers (in a router table).
In my case, the lathe is a floor model with a 2 hp motor.
I was told, quite convincingly, that my motor was not designed for that and that I would, in due time, damage my motor. I didn’t pursue it further.
I hope someone else who understands this better than me and offer additional advice and insight.
View lew's profile
11984 posts in 3688 days
#2 posted 08-12-2010 05:01 AM
Also, you are looking at two very different types of motors. Motors used on a lathe require special variable speed controls that will not damage the windings- as Rich pointed out.
