Can't square 6" Jet jointer fence
Forum topic by DygertDesigns27 posted 12-19-2016 08:07 PM 760 views 0 times favorited 4 replies Add to Favorites Watch
View DygertDesigns27's profile
DygertDesigns27
1 post in 581 days
12-19-2016 08:07 PM
Topic tags/keywords: 6 jet jointer jet jointer jj-6os jj 6os square jointer square set up
I recently purchased a 6” Jet open stand jointer model JJ-6OS. I tested the squareness of the fence to the table and it’s slightly off. When I loosen the lock-down lever (?) I can manually square the fence but as soon as I retighten the lock-down lever that keeps the fence from moving, it pulls the fence back out of being square. I googled manuals for the jointer but the pictures and descriptions don’t match my jointer even though the model number on my jointer matches the manuals I find online. Does anyone know anything about an alternate manual for the JJ-6OS, or is anyone able to help direct me on maintaining squareness of the fence as I lock it into place? Thanks so much in advance!
View splintergroup's profile
splintergroup
2153 posts in 1278 days
#1 posted 12-19-2016 08:26 PM
I have the cabinet version (6cx?).
I recall the fence tilt adjust stop being stubborn, there is enough slop in the jam-nut setup that you need to compensate in a trial and error approach.
Once the stop is set correctly, I hold the fence against the stop with the handle, then lock the tilt lever.
If you are not using the stop, cleaning the surfaces where the lock lever bites in will help (remove paint, burrs, etc.)
Also inspect the washer for flatness.
View knotscott's profile
knotscott
8080 posts in 3431 days
#2 posted 12-19-2016 08:50 PM
As an alignment aid, these HF magnetic welder’s square are cheap and useful.
View syenefarmer's profile
syenefarmer
496 posts in 3136 days
#3 posted 12-20-2016 12:02 AM
I use a Wixey Angle Finder to sneak up to 90° on my jointer, also a Jet.
View AshTheArtist's profile
AshTheArtist
28 posts in 592 days
#4 posted 12-20-2016 12:22 AM
I have jet 10BTOS so i feel your pain.. that what I do. If you have two 90 squares, you can clamp them at either side of fence after loosing the lever. To the fence and with the bed using 4 clamps. Then tighten the lever.
-- Ash @ touchwoodarts
