| Forum topic by Blake | posted 1016 days ago | 3965 views | 0 times favorited | 32 replies | ![]() |
1016 days ago |
I have a pair of shooting ear muffs that I bought for $15 that keep out almost ALL the noise, but they don’t play my music. I bought three different noise-cancelling “studio” headphones that totally cover the ear. I RETURNED each because they don’t block enough outside noise and the noise-cancelling feature only adds a hissing sound. I bought a pair of WorkTunes despite the mixed reviews… they block out all the noise but the music quality with my ipod was TERRIBLE! So I returned them too. The best solution I’ve found so far are the ear buds from my ipod under my shooting ear muffs… this blocks out the noise and gives me great audio quality… but its very uncomfortable for long periods of time. What am I supposed to do??!! Why hasn’t someone made headphones that block out the nose but also have decent speakers inside them? It doesn’t seem that difficult. I don’t even need a radio, I just use my ipod.
-- Happy woodworking! http://www.blakeweber.us |
32 replies so far
#1 posted 1016 days ago |
Have you thought of just sticking your ear buds in your ears since you plan to use your I Pod? Just a thought. -- I don't make mistakes, I have great learning lessons, Greg |
#2 posted 1016 days ago |
There are a whole line of earbuds called canalphones that are more like earplugs with small acoustic chambers inside that play the music. I own a pair made by ultimate ears, but shure, klipsch, bose, skull candy, etc. all make pairs. Mine are rated at 26 dB passive attenuation, which is about the same as a pair of foam earplugs. I work with my planer going and my mp3 player at about 10% of max volume with no problems. They are not cheap, however. Probably at least $70 to get in to the less expensive ones. -- Brian T. - Exact science is not an exact science |
#3 posted 1016 days ago |
I have a pair of the Ryobi battery powered Noise Canceling HeadPhones , they work great at cutting the noise down . Mostly use them with out the battery which runs the microphone part of the headphones . That lets you have a conversation with someone with out removing the HPs . As for the music part , the sound doesn’t get very loud , so if that’s what you’re looking for , these aren’t the HPs for you . I doubt very much you’ll find a NC HP that lets you listen to music loudly . I think that kinda goes against the whole NCing thing . |
#4 posted 1016 days ago |
I have a pair of noise isolating (fit in the ear) ear buds I got from Costco for $20. They are comfortable -Bryan |
#5 posted 1016 days ago |
Ramsey Electronics has a low power FM transmitter that I use with my “Work Tunes”. This will also do away with the wire between your earbuds and MP3 player. The kit is easy to build and has a range of about 250’ depending on the structure. I have mine hooked to my computer and play Itunes or any internet music source. This also lets anyone with a radio or other “Work Tunes” listen to the same music. http://www.ramseyelectronics.com/cgi-bin/commerce.exe?preadd=action&key=FM10C Hope this helps. -- When tempted to fight fire with fire, remember that the Fire Department usually uses water. Gfolley, Ohio |
#6 posted 1016 days ago |
I bought a pair of Koss “The Plug” ear buds for about $5 some years ago, then several spares since they were good. They are a bit like ear plugs – roll the foam to compress, then it expands to fill your ear. And pretty good sound, perhaps a touch heavy on bass for my taste. Good enough for blocking sound on an airplane, but not good enough to block shop sounds. So start with these for the music, then get comfortable sound-deadening muffs to go over them. DON’T expect muffs with speakers to sound good. Instead, get some buds you like, and some muffs that are comfortable and kill sound, and you’re golden. -- Mark, hack amateur woodworker, Medford (greater Boston) MA |
#7 posted 1016 days ago |
I use Motorola T820 Bluetooth Stereo Headset. They cut most of the noise out, I have it paired with my PC but you can also use it with your mobile phone. -- __A Clean Desk is a sign of a sick mind.__ |
#8 posted 1016 days ago |
I find it impossible to focus on my work and listen to music at the same time…..........everytime some ass seems to think that he/she can multitask….................I wind up paying for it ear protection that plays music is nothing more then stupid when trying to focus on router bits, kick backs, measurements, grain direction, joinery…..................those who beg to differ…........thier work is most often more expensive then it should have been. music should always be a mild distraction, never the focus. in the end, inherint background noise is always going to be the “partner”, the wife, the nag, the MIL, the FIL, the SIL, the DIL, the cousin, the aunt, so if up to me, I save the ear phones and music for the hammock and pretend they all dont exist ? -- "Good artists borrow, great artists steal”…..Picasso |
#9 posted 1016 days ago |
Oh Man, the worktunes was coming up fast on my “Tools I Want” list. I was that close to buying a pair off amazon. Thanks for the heads up. Actually, I had read some negative reviews and settled on the Bilsom. They have a good reputation, especially from former worktunes owners- slightly pricey but doable. http://www.amazon.com/Bilsom-1015543-Stereo-Hi-Vis-Earmuff/dp/B0027DIHZS -- david roberts, spinning Tales from Topographic Oceans, no, really. |
#10 posted 1016 days ago |
Blake, Have you tried the very same setup you are using now but substituting the Apple In-Ear Headphones for the standard ones? They are very comfortable for long periods of time (They are the only ones I use and I often do listen do audiobooks and podcasts for hours a day.) and you have the inline remote on the wire. Jojo |
#11 posted 1016 days ago |
I wear hearing aids so ear buds are out for me. I had some muffs from work and a few head sets that were broken. I took the speakers off one of the old headsets and put them behind the stuffing in the muffs. That gave them a more mellow sound and work well for mowing the lawn, shop work and I can still listen to Rush on the radio. -- Loving it in Tucson .... Stephen |
#12 posted 1016 days ago |
Why can’t someone invent a blue tooth MP3 and WiFi enabled gizzmo for us simple minded folks. I listen to Pandora radio on my Iphone on a docking station in my shop. I hear ya. I was just looking at a pair you so eloquently gave the thumbs down on. Thanx for the frustration saver. -- I'd like to believe Murphy's Law haunts my woodshop, because if it's Karma it would mean I had something to do with it. - K.R. |
#13 posted 1016 days ago |
Ryobi Audio Plus RP4530
-- shdesign3.com |
#14 posted 1015 days ago |
IMHO fancy ear muffs fall into the gadget section. Buy a $2 set of earplugs on a string, put them in when you need them and pull them out when you’re done. I’m with moron, the slighest distraction in a shop can turn into the biggest accident. Besides, if your busy listening to a song, how are you supposed to think through the problems of the world. -- http://www.niceashplanes.com/ http://www.efcabineture.com/ |
#15 posted 1015 days ago |
I got two sets of AO Safety Blockade earbuds (reviewed here on LumberJocks) on a special at Woot.com, and I’m mostly overjoyed with them. They’re in-ear, so not everyone can wear them, but they do a great job at blocking out the sound, and are good enough for listening to podcasts. Unfortunately, that blowout on Woot was probably the last of the inventory, as every search for them shows them as “out of stock”. I’ve heard good things about the Etymotic ear buds, but don’t have personal experience, and they are pricey. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
