Removing TONS of glue squeeze out
« back to Joinery forum
Forum topic by kocgolf posted 12-18-2016 09:28 PM 1638 views 0 times favorited 23 replies Add to Favorites Watch
View kocgolf's profile
kocgolf
310 posts in 2175 days
12-18-2016 09:28 PM
I got lazy doing a couple cutting board glue ups the other night because I was in a hurry. I used an abundance of Titebond III and didn’t bother to clean up the squeeze out while wet. The top wasn’t so bad, but when I unclamped this morning it is a mess on the bottom. Usually I use an old chisel or card scraper, but this thing is going to be brutal. Anyone have any secret tricks up their sleeve or am I in for a long night of scraping, sharpening, and repeat? Also, how bad would it be to run through the planer, NOT when it’s raised chunks yet, but when it’s down to just smears. I think it’s going to take a run through to get it perfectly flat anyway.
23 replies so far
View JAAune's profile
JAAune
1798 posts in 2313 days
#1 posted 12-18-2016 09:33 PM
Hot vinegar might help but it might also cause other problems by reacting with the wood (depends upon species) and causing discoloration.
Running it through the planer won’t hurt the cutting board but it may gum up and dull the knives prematurely.
Those paint scrapers they sell at the hardware store are good for cleaning off large amounts of dried glue.
View HorizontalMike's profile
HorizontalMike
7756 posts in 2910 days
#2 posted 12-18-2016 09:37 PM
IMO, use a hammer and a sharp chisel. Power tools will just gum-up the issue.
View madts's profile
madts
1862 posts in 2336 days
#3 posted 12-18-2016 09:49 PM
Use a slick. One of the greatest tool ever. 2.5 wide chisel and 3 foot long. Used in lumber framing.
—Madts.
-- Thor and Odin are still the greatest of Gods.
View Kazooman's profile
Kazooman
1006 posts in 1949 days
#4 posted 12-18-2016 10:00 PM
A paint scraper works well and it is easy to resharpen the edge on a sheet of sandpaper placed on a flat surface like the table of a drill press. Soften the corners of the blade to avoid digging into the workpiece.
Do you own a drum sander? A 60 or 80 grit belt would make quick work of that glue. Might need to reserve that belt for dealing with glue in the future.
kocgolf
#5 posted 12-18-2016 10:14 PM
Ah, good suggestions. I have a sharp paint scraper I use for removing hot glue on templates and planer sled. I’ll try that. I have a friend in town with a thickness (drum) sander that I could hit up if that doesn’t work.
madts, I have never heard of a slick, but it sounds awesome:) I think I need one.
Kazooman
#6 posted 12-18-2016 10:32 PM
Ah, good suggestions. I have a sharp paint scraper I use for removing hot glue on templates and planer sled. I ll try that. I have a friend in town with a thickness (drum) sander that I could hit up if that doesn t work.
- kocgolf
Yep, remember Teddy Roosevelt’s advice to woodworkers: “speak softly and carry a big slick”.
Think of a slick as a wood chisel on steroids. You can rally lean into it and apply a lot of force.
View rwe2156's profile
rwe2156
2925 posts in 1477 days
#7 posted 12-18-2016 10:32 PM
You’re in for a workout.
36 grit sandpaper on a belt sander…....carefully
4984 posts in 2490 days
#8 posted 12-18-2016 10:34 PM
That paint scraper is going to get a lion’s share of it off, and maybe easier than some other methods. But I’d think carefully about running it through a DS, even with the majority of it removed, PSA can clog a DS belt very quickly.
View WillliamMSP's profile
WillliamMSP
1084 posts in 1601 days
#9 posted 12-18-2016 10:39 PM
Not that I’ve ever laid hands on the thing, but I just read about it in the PWW gift guide earlier today and this sounds like a perfect job for it, the Benchcrafted Skraper -
http://www.popularwoodworking.com/woodworking-blogs/the-anarchists-editors-gift-guide-item-2-benchcrafted-skraper
-- Practice makes less sucky. (Bill, Minneapolis, MN)
View BulldogLouisiana's profile
BulldogLouisiana
325 posts in 1137 days
#10 posted 12-18-2016 10:53 PM
Grinder with a wire wheel attachment. Easy.
-- There are 10 types of people in the world. Those who understand binary and those who don't.
kocgolf
#11 posted 12-18-2016 11:14 PM
I had the scraper on my wishlist last year. I typically just add everything from Schwartz’s presents list:)
View cracknpop's profile
cracknpop
294 posts in 2345 days
#12 posted 12-19-2016 04:39 AM
I grab my belt sander and knock it down before running it through the drum sander.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
View builtinbkyn's profile (online now)
builtinbkyn
2273 posts in 937 days
#13 posted 12-19-2016 05:00 AM
It’s a little expensive for the limited use it may get, but it’s also one of my favorite tools to use. Dried glue flies off at an amazing rate. Just wear eye protection.
http://www.highlandwoodworking.com/kunzgluescraper.aspx
I’ve also used it in an “improvised” manner for some other tasks that at the moment I can’t recall :)
Edit: Wanted to add – unlike store bought paint scrapers, this thing has mass that helps it plow thru hard, dried glue. It really helped when it was time to clean up the squeeze out on my bench build. But it’s also gotten plenty of use on other projects. It has a cast iron handle and a 3/16” think blade that’s razor sharp. For me, it makes removing the squees out fun as it literally plows thru the hard glue. Ah I guess you’d have to experience it first hand to find out :)
-- Bill, Yo!......in Brooklyn & Steel City :)
kocgolf
#14 posted 12-19-2016 12:51 PM
I’m going to have to consider one of those two scrapers for sure. I put a decent edge on a paint scraper and it did an ok job on the first board, although it took a little nick out of the cherry. Not the blade, because I broke the corners, but it seems I got a little too fast and the glue must have pulled it off. Should sand or plane out ok though.
View jbay's profile (online now)
jbay
2281 posts in 896 days
#15 posted 12-19-2016 02:13 PM
Might try one of these cheese graters made for bondo.
