| Forum topic by ronald | posted 313 days ago | 381 views | 0 times favorited | 19 replies | ![]() |
313 days ago |
313 days ago |
I really like my Grizzly 14” Ultimate. It makes the blade go around! -- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com |
313 days ago |
Ron… I have a Jet 14” myself; the only thing I wish I had done differently is the following: 1) buy the next model up with dust collector port Did do: -- Chris |
313 days ago |
I would get a name brand, Grizzly, Jet, Delta, Powermatic… not some off the wall brand. -- Gary, East TX -- The longest journey begins with a single step. |
313 days ago |
Powermatic is expensive, but it comes all tricked out with carter guides, tension release, and they currently include a riser block and mobile base in a promotion at woodcraft. Many times if you buy a lesser brand, you will later want to add all of this and end up paying more in the long run. Just make sure you get a brand that has service if you need help with your took later. -- making sawdust.... |
313 days ago |
I have a 14” Grizzly with a riser block. It does everything I want it to do. -- Maplewood, MN |
313 days ago |
I agree with motthunter’s advice. I too have a 14” powermatic and, even though it is more expensive, when compared with Jet, Grizzley etc. factoring in the upgrades that come with the tool make it a wash in my opinion. But irrespective of the brand, a 14” tool should be just fine for most amateur needs. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
312 days ago |
This is the kind of information I needed to make a choice. One other brand comes to mind , Steel City . Anyone have an opinion on this brand ? |
312 days ago |
My 14” Grizzly Ultimate is a fine BS. Tension release, very good fence, tracks good, everything I need it for, it does. Steel City wasn’t making the BS when I got my Griz so I have no opinion on them. I do have a very good opinion on their Mortiser though. ONE FINE MACHINE is all I can say. Wayne -- My Father was my mentor for my woodworking hobby and knowledge. Luv ya Dad. |
312 days ago |
I would however reccommend TIMBER WOLF blades from Sufolk Machinery. Wayne -- My Father was my mentor for my woodworking hobby and knowledge. Luv ya Dad. |
312 days ago |
Someone else just mentioned Timber Wolf on another thread. -- Maplewood, MN |
312 days ago |
I have been using my Delta 14” for about 10 years now and it works great. I like the Woodslicer from Highland Hardware. The variable 3 and 4 tpi eliminates vibration and -- Gary, East TX -- The longest journey begins with a single step. |
312 days ago |
Blake might have one to sell. -- Karson Southern Delaware karson_morrison@bigfoot.com |
312 days ago |
Go Karson! -- North Texas |
305 days ago |
I just received my Grizzly GO555 on Friday. This being my first bandsaw, I don’t have much experience with setting one up, and set my expectations accordingly, but I was pleasantly surprised! it took about an hour and a half to assemble, then another 30 minutes to tweak. The blade included tracked just as it should, and I re-sawed a 4 inch wide piece of Texas Ebony, very hard, from 4/4, sliced 3/8ths off it very evenly! A couple passes thru my planer, and it’s ready to be the sole of my new mesquite foreplane. Very pleased with my purchase. -- North Texas |
305 days ago |
Ron, I too have the Jet 14” and love it. I’ve done some upgrades too, but I think some of these are standard in the Jet now: 1. Quick Release Lever…a must on any model What next: 1. New Spring…from what I gather this is something that almost all 14” saws need is an upgraded spring to increase tension, not expensive, and my stock spring was OK at first but now I need to upgrade That’s it for me, now why did I tell you all this??? These are things to look for for your money along with the obvious…i.e. horsepower. I’ve re-sawed a lot of lumber and my jet keeps on going strong. The table is flat and beautifully polished, and the saw runs very, very smooth, can balance a nickel on edge on the table…on a mobile stand! I’ve used the steel city and it did the job, but didn’t seem as well finished as my jet. The others I’m not sure, heard good things about powermatic (same company as Jet) and Grizzily. Heard some nightmares on Delta though. Which ever you buy there will probably be upgrades to be had. Make sure the model and brand can use the upgrades….especially the riserblock….very important. You won’t be happy unless you can increase the inches you have available. Food for thought hope it helps, a bandsaw is one of those invaluable tools that save the day time and time again for me. I know you’ll enjoy having one too. Good Luck! -- Jim Hallada, Chesterfield, VA |
305 days ago |
Karson what size? If this fella doesn’y buy.. Maybe I’d take a look.. Setting up a new shop in the spring..hahaha Oh cr*p now I get it I remember the wobbler…..... Man that seemed super frustrating .. getting the old band saw to be stillllllllllllllllll -- PJM.`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> why's there a light in fridge and not the freezer? , aka, the wood hunter.aka tigermaple5 |
305 days ago |
Gotta throw my Rikon Deluxe 14” into the mix. While I have little experience in the way of comparisons, it exceeded every expectation. I did a review a while back. Check my homepage if interested. 13” resaw without a riser. Tensioning and tracking are as easy as any. Windows allow user to see the blade without opening the saw. Quick Tension release, lamp, and a very decent fence. My only gripe was that the adjustments for blade changes are not as fast as many I’ve seen. However, once set, the factory roller guides are awesome. Gotten several “best” awards from a few magazines. Most noted the blade change issue. A little pricey compared with a Grizzly, but much more reasonable than a Laguna or Powermatic. I’ve used the Grizzly 14” Ultimate and it did well. This was w/o the riser option. It isn’t as nice as the Rikon IMO, but it leaves little to be desired. I’m with most everyone in that a TW blade or a Woodslicer (haven’t used, but it gets some praise) makes a world of difference. -- Jeff, South Carolina |
305 days ago |
I’m very pleased with the Rikon model 10-325 deluxe 14 inch bandsaw I purchased. I replaced the supplied blade with a Timberwolf 111 inch blade. The saw has great resaw capabilities with the 1 1/2 horse motor. The blade guide keeps the blade running true and smoothly. The machine runs quietly and has a very solid feel to it when it is running. The blade tensioning device works well and saves time with no fiddling with the adjustment like on other saws. This saw replaces a 14 inch Grizzly that I could never keep the blade guide in the correct position. -- I started out with nothing, and still have most of it..... Ernest 1. |
303 days ago |
Hi I have been using bandsaws for a very long time and I recently bought the upgrades Rikon 14” upgraded model and it is without a doubt a wonderful saw,lots of power,very large resaw ability and wonderful power,and features.I believe I have used just about every single brand out there and believe the Rikon is a notch above the rest although any of the top brands are wonderful |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1336 |
| Become a sponsor |
1778 |
| Become a sponsor |
123 |
| Become a sponsor |
371 |
| Become a sponsor |
108 |
| Become a sponsor |
Woodworking Trade & Swap
251 |
| Become a sponsor |
Coffee Lounge
1004 |
| Become a sponsor |
LumberJocks.com Site Feedback
284 |
