NEMA Frame size for Delta 17-900 drill press
Forum topic by bob_mcc_ct posted 12-18-2016 03:26 AM 422 views 0 times favorited 1 reply Add to Favorites Watch
View bob_mcc_ct's profile
bob_mcc_ct
4 posts in 432 days
12-18-2016 03:26 AM
Topic tags/keywords: delta 17-900 motor frame size drill press
I am looking to purchase a 3-phase motor and add a VFD for speed control. I cannot locate the frame size of the existing motor.
If anyone has done this with their drill press I would appreciate your advice.
Thank you,
-- Bob McConnell, Redding, CT
1 reply so far
View MrUnix's profile
MrUnix
6353 posts in 2105 days
#1 posted 12-18-2016 04:06 AM
The motor data plate doesn’t list it, but it’s probably a standard 56 frame. If you have the existing one, just measure and look it up:
NEMA electrical motor frame sizes (at Engineering Toolbox)
Too bad you are so far away… I have a 3/4hp 3 phase Dayton just sitting on the shelf gathering dust :(
PS: You might also want to consider a variable speed DC motor. You can get the motor, controller and power supply for free out of an old treadmill. They are typically around 1.5 to 2.5 HP.
