Anyone Have An Easy Method For Cutting These Handles?
Forum topic by spindeepster posted 12-18-2016 01:34 AM 910 views 0 times favorited 17 replies Add to Favorites Watch
View spindeepster's profile
spindeepster
29 posts in 1159 days
12-18-2016 01:34 AM
I’m building honeybee hives and want to cut handles like these. Any idea how it’s done? Thanks!
-- How Come I'm Not In Charge?
17 replies so far
View Breaktime's profile (online now)
Breaktime
1913 posts in 768 days
#1 posted 12-18-2016 01:41 AM
_”I’m building honeybee hives and want to cut handles like these. Any idea how it’s done? Thanks!
—How Come I’m Not In Charge?
Handles like what? No idea!
I guess that’s why your not in charge…LOL
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View REO's profile
REO
927 posts in 1943 days
#2 posted 12-18-2016 01:57 AM
Those have been done on a shaper. They can be closely duplicated on the table saw by feeding the material parallel to the arbor. proper jig or fixture required.
spindeepster
#3 posted 12-18-2016 02:01 AM
I know just how you feel jbay. I remember the first time I drank a whole beer all by myself too…
View marc_rosen's profile
marc_rosen
129 posts in 3050 days
#4 posted 12-18-2016 03:20 AM
Hey Spin,
I helped a friend with his bee boxes and we used a plunge router fitted with a bowl bit and a template for guidance. We’re in Northern Baltimore County. What types of foliage will your bees be foraging in?
Marc
-- Windsurfing, Woodworking, Weaving, and Woodducks. "Most woodworkers are usually boring holes"
View mrbob's profile
mrbob
182 posts in 438 days
#5 posted 12-18-2016 04:14 AM
Why do you need that style handle?? Adjust/adapt a different handle you can make.
mrbob
#6 posted 12-18-2016 04:15 AM
Core bit and a guide
View waho6o9's profile
waho6o9
8064 posts in 2446 days
#7 posted 12-18-2016 04:36 AM
Breaktime
#8 posted 12-18-2016 04:38 AM
I remember this being discussed before and did a search. Try these.
http://lumberjocks.com/CueballRosendaul/blog/41441
http://lumberjocks.com/SASmith/blog/29309
waho6o9
#9 posted 12-18-2016 04:38 AM
Or, get the router bit with a top bearing and just follow the template.
Practice on scrap until you get the hang of it and you’ll be good to go.
View REO's profile
REO
#10 posted 12-18-2016 03:04 PM
the problem with plunged handles without a taper on the bottom facing surface is water shed. the edges give water a place to stand and can lead to rot.
View wichman3's profile
wichman3
60 posts in 490 days
#11 posted 12-18-2016 04:22 PM
How comfortable are you with your RAS? Can you clamp a board flat to it’s surface? Can you lock the rail at a predetermined distance from the fence?
Here is an example of a handle I cut with my 12” siding miter saw. I locked the slide at the far extension, then adjusted the depth stop to half the thickness of the piece and loosened the lock to be able to rotate the saw.
I cut at 90 deg then made progressive cuts at several angles until I got to 45 deg, then made one cut at depth rotating the saw between 45 and 90 deg.
View Loren's profile
9752 posts in 3517 days
#12 posted 12-18-2016 04:45 PM
Anothyer thought… one can rout out
the back to 1/4” deep, cut a oval hole,
then glue a 1/4” thick patch in at the
back.
The reason for this sort of handle is because
the hives get real heavy when loaded with
honey.
View Dark_Lightning's profile
Dark_Lightning
3017 posts in 2978 days
#13 posted 12-18-2016 04:51 PM
You can do it in two passes- straight bit for the flat part, then core box bit for the curved section.
-- Random Orbital Nailer
View gwilki's profile
gwilki
175 posts in 1343 days
#14 posted 12-18-2016 09:30 PM
Put a stacked dado set onto your table saw. Lower it below the table. Clamp the piece down to the table and raise the dado set into the piece. The trick is to keep track of how many turns you raise the dado set, so that you don’t go through the piece and the handles are all the same.
-- Grant Wilkinson, Ottawa ON
spindeepster
#15 posted 12-19-2016 01:24 AM
Thank you all for the input. At this point in the construction of the hive, I’ll need to come up with something else. I’ll probably cut some cedar and attach handles on the outside of the boxes. As mentioned above, there is a lot of weight to a super with frames loaded with honey. That’s what makes the handles in the above picture ideal.
