Router inlay guides
Forum topic by JustLikeJames posted 12-17-2016 04:41 PM 471 views 0 times favorited 4 replies Add to Favorites Watch
View JustLikeJames's profile
JustLikeJames
173 posts in 1645 days
12-17-2016 04:41 PM
Topic tags/keywords: guide bushing inlay bushing
Router inlay kits always include a template guide/collar with a snap-on bushing and a downcut spiral bit. If I already have a regular set of guide bushings (without a snap-on bushing), can I get by with those rather than spend $ on the snap-on bushing kit? I need to do some butterfly keys, bowties, dovetail keys, whatever name they go by. Is the snap-on bushing just a time saving convenience or is it more precise (tighter joint) than using two different sized guide bushings?
Thanks in advance.
View jerryminer's profile
jerryminer
937 posts in 1524 days
#1 posted 12-17-2016 08:51 PM
The bushing kit is designed to be the perfect offset for the bit diameter. You can live without it, but you may have to “fine-tune” the fit. You can adjust a bushing by wrapping tape around it, or fine-tune either the inlay or the recess with hand tools.
MrUnix
6845 posts in 2281 days
#2 posted 12-17-2016 09:10 PM
The inlay kit just makes it easier since you don’t have to swap out guide bushings. If you have the correct sized bushings and bit already, go for it.
MrUnix
#3 posted 12-17-2016 09:11 PM
Oh – you might want to do a few practice runs first :)
JustLikeJames
#4 posted 12-17-2016 09:23 PM
Thanks all. I think I’ll get just the bit at this point and give it a shot. I’m sure I’ve got two guide bushings that are 1/8” difference between them. If it’s too much trouble, I’ll buy the whole kit next time.
Thanks
