Acrylic pen turning question
Forum topic by deucefour posted 08-10-2010 02:00 AM 2739 views 0 times favorited 10 replies Add to Favorites Watch
View deucefour's profile
deucefour
285 posts in 3452 days
08-10-2010 02:00 AM
Topic tags/keywords: question
Just wondering what you guys use to keep the tube from showing through some of the more translucent acrylic blanks, I am aware of using a magic marker but what about when it is a lighter color such as a light blue? or pink?
thanks in advance for your help
Robert
10 replies so far
View Eagle1's profile
Eagle1
2066 posts in 3263 days
#1 posted 08-10-2010 11:49 AM
I don’t seem to have any problem’s with them. You might be turning the pens down to thin. If the tubes are brass like the ones I use. I would think it would add to the design.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
View 4thumbs's profile
4thumbs
153 posts in 3345 days
#2 posted 08-10-2010 02:51 PM
Not an elegant solution, but I have just painted the brass tubes prior to epoxying them in the blanks. With the tubes thoroughly roughed up prior to applying a thin coat of enamel it seems to work fine; no separation of tubes from blanks in pens made over a decade ago…
-- 4thumbs in MO
View JerrySats's profile
JerrySats
237 posts in 3808 days
#3 posted 08-11-2010 02:46 AM
Besides painting them , you can find colored tubes for most of the popular kits .
deucefour
#4 posted 08-11-2010 02:40 PM
Thanks for your suggestions gentlemen,
4 thumbs, do you use spray paint?
Jerry, where might one find colored tubes, I have never seen them?
Robert
View rance's profile
rance
4266 posts in 3359 days
#5 posted 08-11-2010 03:02 PM
Colored tubes(white) at Woodcraft & PenState too I believe. My most often used fix.
Spray paint works. You can paint either the tubes or the hole.
Markers can work too.
Can also put pigment in epoxy.
You’re not turning them too thin, you’re just using blanks that are semi-transparent. Some blanks I won’t buy because of this (Woodcraft-Strawberry, for instance).
deucefour
#6 posted 08-11-2010 03:29 PM
Great info, Thank you all for your time.
Robert
JerrySats
#7 posted 08-12-2010 02:17 AM
Robert
Rance already mentioned a few , another place is http://www.arizonasilhouette.com/Berea_Hardwoods_Pen_Kit_Brass_Tubes.htm
Also Craft Supplies USA has a product called “Chameleon Pen tubes ” http://www.woodturnerscatalog.com/store/Pen_Making___Pen_Components___Chameleon_Pen_Tubes___chameleon_tube?Args=
If you haven’t done so already sign up for their email specails , they have some nice discounts at times .
JerrySats
#8 posted 08-12-2010 02:19 AM
Did a double tap .
deucefour
#9 posted 08-13-2010 10:09 AM
All good info, thanks ya’ll
View Sawdust2's profile
Sawdust2
1466 posts in 4286 days
#10 posted 08-13-2010 12:53 PM
Some people spray.
Some people use Q-Tips or an acid brush.
Any enamel will do. Lot’s of folks swear by Testor’s from any hobby shop. Lot’s of colors and the small amunts won’t break the bank for small jobs.
Some people paint the inside of the blank, some the tube, some both.
Some mix the color with epoxy glue.
There is more than one video on YouTube about painting pen blanks.
