Hammer Veneer Staining
Forum topic by jonsprague0000 posted 12-16-2016 02:38 AM 656 views 0 times favorited 9 replies Add to Favorites Watch
View jonsprague0000's profile
jonsprague0000
104 posts in 1828 days
12-16-2016 02:38 AM
Topic tags/keywords: venner hammer veneer hot hide glue hide glue marquetry stain maple curly maple
I hammer veneered two pieces of curly maple with HHG and went to re-hammer a few bubbles. During the hammering I noticed a few dark streaks appearing, but just thought that the veneer hammer was just marking the wood slightly due to the water and friction. I figured I could just lightly scrape it off. After I finished I went to scrape and sand, but the spots seem to be deep stains. I’m afraid I will sand right through the veneer trying to remove them.
Has anyone experienced this before? Help! I’m afraid I’m going to have to re-do the project. My hammer is a Kunz (I assume cast iron) hammer. I cleaned it before hammering with vinegar and also used some vinegar to remove glue on the veneer. I’m assuming that isn’t related, but wanted to mention that.
9 replies so far
jonsprague0000
#1 posted 12-16-2016 02:38 AM
Shipwright – I assume you may have experience with this?
View shampeon's profile
shampeon
1895 posts in 2423 days
#2 posted 12-16-2016 03:54 AM
What kind of wood is the veneer and substrate? Vinegar will definitely stain high-tannin woods like oak.
You could try to use oxalic acid to remove the stain, but it depends on the veneer, etc.
jonsprague0000
#3 posted 12-16-2016 04:15 AM
The veneer is curly maple with a wood backer. I’m not sure of what type of wood the backer is. The substrate is eastern white pine. I put the vinegar on the veneer around 10 minutes before hammer veneering and didn’t notice any change. I only saw the change after starting to hammer. It felt like it was coming from the veneer hammer, but I can’t be positive.
View Lazyman's profile
Lazyman
2707 posts in 1626 days
#4 posted 12-16-2016 04:37 AM
It will help if you post some pictures.
jonsprague0000
#5 posted 12-16-2016 06:10 AM
Here is the stain and what it looks like after I scrape it off. I had to go down far to get the majority of it off and there is only an extremely thin piece of veneer remaining.
I tried another piece without vinegar and noticed the start of slight coloring.
View shipwright's profile
shipwright
8187 posts in 3037 days
#6 posted 12-16-2016 03:16 PM
If you are using a two ply veneer then that will be your problem. You are likely seeing the glue line between the microscopically thin curly maple and the backer. Get some raw veneer, as thick as you can find, and try again. 1/42” is about the norm these days but 1/32” is still around but harder to find. Good luck.
No need for the vinegar. Hide glue cleans up with water.
jonsprague0000
#7 posted 12-16-2016 05:56 PM
Paul, I was able to use a scraper and remove the majority of the staining so I don’t believe I’m seeing through to the glue line. When I re-hammer to press bubbles down I’m seeing the markings only where I’m pressing down very hard. I then see tinted hide glue on my veneer hammer.
I’m thinking it could either be the hammer iron or finish coming off. Or maybe the 2-ply glue seeping through the wood pores? Is that possible?
Have you ever seen an iron (I think) hammer cause issues like this? Do you use brass?
shipwright
#8 posted 12-16-2016 10:07 PM
I’ve used brass but my current hammers are steel and copper and no such problems. You may be getting a stain from the metal but your top photo above really looks like the factory glue (likely a urea formaldehyde) showing through.
Regardless I wouldn’t consider using that stuff for this kind of woodworking (just my opinion). Raw veneer is so much better, even the thin sliced stuff we are able to get today. Some places sell limited species in 1/16”, notably Certainly Wood but there are others. For what you are doing, the thicker you can use, the better, even more so if you get into marquetry.
View punkin611's profile
punkin611
49 posts in 1061 days
#9 posted 12-17-2016 02:19 AM
The discoloring is caused by reheating the two ply veneer too hot in an effort to get the veneer to relax enough to hammer down. The glue in the veneer ply is not hide glue. You cannot hammer down two ply veneer. Reheat and take it all off. If you do not want to use raw veneer(which you should IMO) get a vac. bag or use clamps and cauls. Hammer veneering with hot hide glue is easy with raw veneer plenty of video on web to get you on right track. Good luck.
