grinder
Forum topic by Karda posted 12-15-2016 07:23 PM 479 views 0 times favorited 4 replies Add to Favorites Watch
View Karda's profile
Karda
1222 posts in 670 days
12-15-2016 07:23 PM
HI, i I made up a grinder to sharpen my carving knives simple 2 wheel arbor. But when I changed wheels I cAN ONLY get one nut tight because the other loosens. how can i get both tight thanks
View Wildwood's profile
Wildwood
2406 posts in 2251 days
#1 posted 12-15-2016 08:11 PM
One arbor end should have right hand threads and the other left hand so nuts don’t come loose. Grinder nuts should only be hand tight, or snug down with a wrench. I always hold one wheel when tightening the other wheel nut.
-- Bill
Karda
#2 posted 12-15-2016 08:44 PM
when I do just hand tight one or both wheels come loose
View HokieKen's profile
HokieKen
6153 posts in 1254 days
#3 posted 12-16-2016 03:52 PM
I always just hold the wheel on the end I’m tightening. If there’s room, you may be able to grind a couple flats on the arbor behind the wheel and stick a wrench on there to hold while tightening. My grinder came with the wrench flats but I don’t think I’ve ever used them.
-- Kenny, SW VA, Go Hokies!!!
Karda
#4 posted 12-16-2016 11:53 PM
thanks that worked
