Need help with cabinet door hinges
Forum topic by jiminlosangeles posted 12-14-2016 10:45 PM 464 views 0 times favorited 3 replies Add to Favorites Watch
View jiminlosangeles's profile
jiminlosangeles
5 posts in 789 days
12-14-2016 10:45 PM
I’m in the process of building new cabinet doors for my kitchen. This is the first time I’ve done this.
When I cut my doors, I made them a little oversized and then trimmed them down to the size I thought they should be. Turns out, I made a bit of a mistake and I now have around a 1/8 inch overlap on the two doors when they are hung. The doors came out great and so I’d like to salvage them. Fortunately, the cabinet I’m installing them on is a stand-alone so if there is a slight difference in the overlay, it shouldn’t be noticeable.
The hinges I’m using are Blum 3/4 inch overlay clip-on European style. Ideally, I’d like to find a 7/8 inch overlay hinge but I haven’t been able to find one. As an alternative, I could use a 1 inch overlay and shim it but again, I haven’t found a clip-on… only a one piece that mounts to the frame. I’d like to avoid that if I can.
Does anyone know where I can get either a 7/8 or a 1 inch overlay clip on hinge? Any help would be much appreciated. I know this was a rookie mistake.
Thanks in advance for the help.
3 replies so far
runswithscissors
2846 posts in 2173 days
#1 posted 12-15-2016 12:19 AM
Rockler, maybe?
View jbay's profile (online now)
jbay
2681 posts in 1048 days
#2 posted 12-15-2016 01:16 AM
Blum has a clip top 110 deg + hinge that goes up to 22 mm
or you can check out the Compact 33’s or the Compact 39C’s
jbay
#3 posted 12-15-2016 03:06 AM
Sugatsune also looks like they have one that might work, depending if you already drilled your cup holes and where.
