What do you do after your last coat of finish (urethane/poly) is applied?
Forum topic by gargey posted 12-14-2016 09:18 PM 3293 views 0 times favorited 20 replies Add to Favorites Watch
View gargey's profile
gargey
1013 posts in 892 days
12-14-2016 09:18 PM
For polyurethane, or urethane, or other finishes of that type (including GF Arm-R-Seal topcaots etc), what do you do after you apply the last topcoat?
Do you buff? Very very fine sand? Wax? Leave as is?
Also Arm-R-Seal says to not apply wax for 30 days (before its fully cured). People follow that in practice?
Just curious on best practices.
Thx
20 replies so far
View mrbob's profile
mrbob
182 posts in 685 days
#1 posted 12-14-2016 09:33 PM
OOOO steel wool with paste wax, buff, then just a coat of wax, buff.
View pintodeluxe's profile
pintodeluxe
5739 posts in 2929 days
#2 posted 12-14-2016 10:00 PM
While steel wool and paste wax is the traditional method, I don’t do that anymore.
I have found that wet sanding with 1500 grit provides a nicer finish, and there’s no wax residue to contend with.
Just a spray bottle of tap water, and a soft sanding sponge is all you need.
View Bill White's profile
Bill White
5048 posts in 4077 days
#3 posted 12-14-2016 10:01 PM
mrbob has the plan. That’s what I do, though I don’t use polycrapithane on anything but table tops.
Bill
-- bill@magraphics.us
View bondogaposis's profile (online now)
bondogaposis
4925 posts in 2467 days
#4 posted 12-14-2016 10:15 PM
Rub it out with a brown paper sack and wax.
-- Bondo Gaposis
gargey
#5 posted 12-14-2016 10:15 PM
What does this do, if I may ask? Even out and smooth the finish? Make it more glossy? Make it more satin-y?
While steel wool and paste wax is the traditional method, I don t do that anymore.
I have found that wet sanding with 1500 grit provides a nicer finish, and there s no wax residue to contend with.
- pintodeluxe
gargey
#6 posted 12-14-2016 10:16 PM
Same question here, how does this advance the finish? Also, are you then stuck in a cycle of having to reapply wax periodically? Thanks.
- bondogaposis
mrbob
#7 posted 12-14-2016 10:25 PM
- bondogaposis
- gargey
Brown paper bags have a ruffness to them that will smooth the finish a bit.
If you wax once nothing sez you have to do it again, personal preference.
View jbay's profile (online now)
jbay
2583 posts in 1015 days
#8 posted 12-14-2016 10:32 PM
I usually strip it and apply a few coats of lacquer…. :>/
View MrUnix's profile
MrUnix
6884 posts in 2315 days
#9 posted 12-14-2016 11:01 PM
Don’t do anything. After applying however many coats needed, I’ll let it cure overnight. Once fully dry, I’ll give it a very light once over with some 600 grit sandpaper,, wipe on a final coat of poly and call it done.
gargey
#10 posted 12-14-2016 11:27 PM
Also unsure how much wipe on poly (actually urethane (Arm-R-Seal)) to apply. So thick that it appears glassy smooth, or wiped off so that you see the texture of the grain?
Tough to figure out without any teaching etc.
I have not dared to leave so much on that it appears glassy while wet.
mrbob
#11 posted 12-14-2016 11:44 PM
- gargey
All depends on the look you want.
pintodeluxe
#12 posted 12-15-2016 12:02 AM
I grew up helping my dad finish wood projects, and he always left the final coat intact without any special treatments. The problem is you will always have some degree of dust knibs or overspray here and there.
The final rubbing out process makes a piece of furniture smooth to the touch, and welcoming to the hand.
Both the wax -n- wool and the wet sanding method work, but I’d rather not deal with the wax.
In response to gargey’s question if this makes it glossy? I usually spray lacquer in a semi-gloss or satin finish. Wet sanding the final coat doesn’t change the sheen much. It just softens the look a bit. Semi-gloss will look more like satin, and satin will look more like a low-luster hand-rubbed finish.
View OSU55's profile
OSU55
1831 posts in 2106 days
#13 posted 12-15-2016 01:18 AM
600 or 800 dry sand, very light just to smooth nibs or whatever. Then gray scotchbrite mounted on a drill sanding pad to even out the sheen. The depending on the desired end sheen, nothing, white scotchbrite, brown paper, again drill mounted. This is for tops only. Other surfaces get less of the same just to get a nice feel. Best to let cure 30 days. Never use wax. Use Meguiars auto cutting and polishing liquids if needed and finish with their sybthetic sealant – no buildup, streaks, or other problems caused with furniture wax. No concern with silicone – the finish is complete.
I I don’t use oil-based poly on furniture anymore for several reasons. Prefer to spray water-based poly for that. I do still use some on turnings
bondogaposis
#14 posted 12-15-2016 02:44 AM
Rubbing w/ a brown paper sack removes any final dust nibs that might have settled in the finish and waxing adds a bit of protection to the finish. You can renew it periodically if you want to or not, it doesn’t lock you into anything.
-- Bondo Gaposis
View ArtMann's profile
ArtMann
1041 posts in 932 days
#15 posted 12-15-2016 04:45 AM
One thing a final coat of wax does is it leaves a silky smooth surface that is a pleasure to touch. If you do wax, you will need a rigorous maintenance schedule that follows. Once a year, get an old T shirt or other soft cotton fabric and wipe or buff the object to remove dust and finger prints.
