A new band saw
Forum topic by Diggerjacks posted 12-14-2016 07:35 PM 420 views 0 times favorited 3 replies Add to Favorites Watch
View Diggerjacks's profile
2229 posts in 3070 days
12-14-2016 07:35 PM
I want to buy ( or perhaps thanks to Santa !!) a new band saw to make some BS boxes
What is the better capacity ?
I have seen the metabo 318 with 170 mm . Is it enough?
Thanks for your advice.
-- Diggerjack-France ---The only limit is the limit of the mind and the mind has no limit
3 replies so far
View ralbuck's profile
4130 posts in 2198 days
#1 posted 12-14-2016 08:14 PM
Not being an expert by any means and not metric educated, I think 170mm ==17 cm—if that is right, it gives just over 6-1/2 inches which is pretty good capacity. I have had 3 bandsaws all much less capacity than that. All were very used when I acquired them and I am currently without one.
Buy the best quality one that you can afford, do the research on the blade carriers and get the best ones right away.
I will not buy a middle of the line or under BS again unless it is a very lightly used estate sale or similar situation and then at a very good price too.
Hope this helps a little.
-- Wood rescue is good for the environment and me! just rjR
View ZAGREB's profile
776 posts in 1581 days
#2 posted 12-14-2016 08:39 PM
mon ami,metabo is the class #1.
maybe you send me your wife mail and I´ll try write to your santa a letter,if is nesseserly I´ll miss a tear,down on my knees,beging,make her laugh…eveyithing…
wish you a good luck
-- bambi
View Roger's profile
20916 posts in 2736 days
#3 posted 12-16-2016 02:11 PM
Good luck in your search Jack. There are lots and lots of good bandsaws out there. You’ll just have to pick one.
-- Roger from KY. Work/Play/Travel Safe. Keep your dust collector fed.
