knife advice
« back to Woodcarving forum
Forum topic by Karda posted 12-14-2016 04:19 AM 1065 views 0 times favorited 8 replies Add to Favorites Watch
View Karda's profile
Karda
1303 posts in 724 days
12-14-2016 04:19 AM
Hi, i am new to wood carving and have been looking at knives. I was wondering how do mora knives rate. I want to keep it simple. I will be manly whittling in the round and making spoons. I read some where that Mora spoon knife are not fun to work with, kinda like using one is more work than it should be any thoughts. Also does anybody know where I can get just blades, I can make my own handle. thanks
8 replies so far
View Picklehead's profile
Picklehead
1043 posts in 2099 days
#1 posted 12-14-2016 01:00 PM
I use a Mora 106 that is very good for spoonwork. Comes razor sharp, is easy to sharpen and use because of the scandinavian (scandi) grind. Very inexpensive, highly recommended. Make sure to get the laminated steel carbon blade, not the stainless blade, for the best edge.
-- You've got to be smarter than the tree.
View Aj2's profile
Aj2
1782 posts in 1968 days
#2 posted 12-14-2016 02:57 PM
I use Helvie knives for my carvings.http://www.helvieknives.com/
I don’t know if they offer blades alone.But Ron Hock might you’ll have to look that one up.
Aj
-- Aj
View AaronZ's profile
AaronZ
8 posts in 1662 days
#3 posted 12-14-2016 03:34 PM
Try Ragnar’s Ragweed Forge. https://www.ragweedforge.com/ He has a great selection with lots of detailed info about each knife or blade, and articles about fitting the handle, making a sheath, and so on. His prices are often better than amazon. I’ve purchased 2 handled mora knives from him and two unhandled blades. I’ll probably eventually split the factory handles off and make my own for those two. His undhandled blades are here: https://www.ragweedforge.com/BladeCatalog.html
View BigNorseWolf's profile
BigNorseWolf
5 posts in 683 days
#4 posted 12-30-2016 04:18 AM
Second the Mora knife. Reasonably priced, and that grind makes the entire thing one long edge. I thought i was doing something wrong all these years that i couldn’t get flexcuts insanely sharp… nope. Everything else is ground wrong.
(i probably AM doing something wrong.. but still. Mora knife, reasonably priced, sharp, and if your fingers will let you hold onto a razer blade you can do everything from rough out work to some real close up detail without switching tools)
Karda
#5 posted 12-30-2016 05:51 AM
yea I love the 106, next i will get the 120 or the 122 when I do small stuff the point gets in the way, a shorter knife would work better. I wish my mora 164 spoon knfe came as sharp as the other, I am having a hell of a time getting a sharp edge on it
View kneegrow's profile
kneegrow
2 posts in 663 days
#6 posted 01-23-2017 03:31 PM
As far as commercial knives I have a Flexcut Carvin’ Jack Knife that I use quite a bit. But my atf is one that I made myself from an old straight blade .
View mpounders's profile
mpounders
894 posts in 3065 days
#7 posted 01-23-2017 03:43 PM
The Moras that I have seen have a really thick blade. That makes them a great general purpose knife for camping and other things and you can get them really sharp. The bevel of the blade, as they come, also helps them hold up well for rougher work. And they are used for a lot of woodcraft and carving in Europe and other countries. All that said, I won’t be buying any for my wood carving! I like Helvie, Drake, OCCT and other knives that have thinner blades and flatter grinds that slice through wood much easier. I don’t care for the grind on Flexcut knives and they are a little thicker than I like, but not as thick as the Moras.
-- Mike P., Arkansas, http://mikepounders.weebly.com
Karda
#8 posted 01-23-2017 05:04 PM
hi, I have a mora 106 and a 120 they seem to do a good job and they are wicked sharp, but the problem I have is with the 164 crooked knife. that has a thick blade but I can’t get a carving edge on it.
