Help with inked/painted wood panels
Forum topic by William Shelley posted 12-13-2016 07:50 PM 406 views 0 times favorited 3 replies Add to Favorites Watch
View William Shelley's profile
William Shelley
553 posts in 1402 days
12-13-2016 07:50 PM
Recently, my girlfriend has gotten me interested in branching out from straight woodworking into drawing and painting a bit. I’ve been doing some projects with India ink brushed onto figured veneered panels (curly maple, currently). I start with a substrate like 1/2” MDF or a decent plywood, glue a sheet of veneer to it, and then sand with 220, then 400, to get a surface that is smooth like paper. After painting, I’ll hit the whole thing with a really light coat of spray lacquer from a rattle can (yeah, I know. but I don’t have a real spray setup), which seals the ink in a bit. Then I can brush on a thinned coat of lacquer, and I do about 2-3 more thicker coats of brushed on lacquer.
The problem: The India ink is water-based and has a tendancy to want to bleed along the grain. I can partially control this if I’m careful and don’t allow the ink to puddle up at all but, as I’m still a beginner at this, I make mistakes. Also, because I’m working with figured wood, there’s unexpected areas of twisty grain and such.
I’m looking for something I can apply to the veneer either before or after sanding to 400 to control the ink bleed, that won’t affect the final finish, but also won’t build a film on the wood fibers, which would prevent the India ink from absorbing and drying properly. I realize this is a tall order but hopefully someone can suggest something that would work.
I’m also open to tips or suggestions to improve the whole process.
I’ve attached a few pictures of what I’ve been working on. This is before any clear coat is applied.
-- Woodworking from an engineer's perspective
3 replies so far
View bondogaposis's profile (online now)
4635 posts in 2284 days
#1 posted 12-13-2016 08:59 PM
You might try a sanding sealer.
-- Bondo Gaposis
William Shelley
#2 posted 12-13-2016 11:48 PM
- bondogaposis
Ok thanks. There appear to be different “sanding sealers”, some are lacquer + zinc stearate, others are dewaxed shellac, or even something else. should I go with the lacquer-based ones as I’m topcoating with lacquer?
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3645 days
#3 posted 01-12-2017 12:07 AM
The shellac may be the way to go as it dries quickly and shouldn’t change the colour of the wood too much. I don’t think it will impede the drying of the India ink.
