New to Woodworking; Need Help With Maple Stump!
Forum topic by polarh posted 12-12-2016 09:37 PM 385 views 0 times favorited 2 replies Add to Favorites Watch
View polarh's profile
polarh
1 post in 586 days
12-12-2016 09:37 PM
a
2 replies so far
View JoeinGa's profile
JoeinGa
7739 posts in 2063 days
#1 posted 12-12-2016 10:41 PM
If it was felled back in the summer, it’s almost too late to worry about cracks. Most likely it WILL crack some. I’ve never seen anyone seal the bark on, but for the cut ends, any old paint I have is what I use.
Drying in a garage? That big of a log will likely take 1.5 to 2 years to dry, unless you split it in half, which will shorten that time greatly
Also WELCOME to LJs !
View crippledcarpenter's profile
crippledcarpenter
26 posts in 2502 days
#2 posted 12-13-2016 01:21 AM
I would agree. use some old paint just to seal the end grains and allow the moister to slowly weep out of the bark. this will help stabilize the piece. push it to the corner of your garage or shed and forget about it for a couple years. after that sand the paint off, level the top and attach the casters. pick your favorite finish(I would put a few coats of tung oil and let it dry) then a hard coat of some poly(oil or water based) and shazam, you will have a coffee table to be proud of
-- haste makes firewood.
