Poly even coat on coffee table
Forum topic by Abn101mp posted 12-12-2016 09:24 PM 577 views 0 times favorited 4 replies Add to Favorites Watch
View Abn101mp's profile
Abn101mp
51 posts in 739 days
12-12-2016 09:24 PM
I’m polyurethaning a coffee table top. Looking for advice on the best way to get an even coat. I have applied the first coat and will be sanding tomorrow with 1200 grit. The customer will be putting a glass top on it so I’m not sure how much time I should really invest in making this as smooth for example, as book cases or jewelry boxes.
I am using minwax semi gloss poly.
Thanks for any suggestions.
-- Dan,Mid-Maine
View crippledcarpenter's profile
crippledcarpenter
29 posts in 2594 days
#1 posted 12-13-2016 01:36 AM
check the product label or call the 800 number and see if the product is able to be wiped on. if yes, this is the best way to control application of most finishing products. spraying the finish is the only way to trump wipe on. as to the 1200 grit sand paper, I would lean toward using steel wool or 3M scuffing pads. you don’t really want to sand per say more to the effect of knocking the high points off the first and second coats of finish. very lite. wipe with a clean dry tee shirt material. I don’t like tack clothes . they can leave wax on the finish and can cause fish eyes in the next coat.
if you do like using a brush or foam applicator, just apply nice thin coats. 3 should produce a beautiful finish you are hoping for.
-- haste makes firewood.
View RogerM's profile
RogerM
798 posts in 2546 days
#2 posted 12-13-2016 01:46 AM
Minwax Polyurethane works just fine when wiping it on. Dilute it with an equal part of mineral spirits then wipe it on with a lint free cloth (I use an old Tee shirt). Wait at least two hours for an additional coat or two. Let cure overnight then rub it out with your 1200 grit sandpaper. After rubbing it out put on a coat of finishing wax with 0000 steel wool and buff.
-- Roger M, Aiken, SC
MrUnix
6943 posts in 2346 days
#3 posted 12-13-2016 03:45 AM
If you can’t spray it, make your own wipe on polyurethane. No need to go out and buy ‘wipe on’ specific crap, as that is just regular poly mixed with mineral spirits, and you pay extra for having them do the mixing. It’s almost foolproof. I am not sure if I agree with Roger about the application process he suggests, particularly about waiting two hours between coats, but you will come to develop your own technique that will work for you. I would also use gloss instead of semi-gloss, as it doesn’t contain the flattening agents that need to be kept mixed before application. If you want a semi-gloss, you can either lay it down as your final coat over the gloss coats, or do something like what Roger suggests using steel wool, fine grit sandpaper, crumpled paper or whatever… wax is optional and gives it a slightly different look and feel as well.
Just for reference, if you check the MSDS of the Minwax wipe on polyurethane, you will see that it’s 70% mineral spirits (CAS #64742-88-7 which they call a Medium Aliphatic Hydrocarbon Solvent), and is even a thinner mix than most people use when making their own – typically about a 50/50 mix.
View Redoak49's profile
Redoak49
3530 posts in 2136 days
#4 posted 12-13-2016 11:54 AM
The Minwax wipe on poly works great for things like you are doing.
