Wet Stain/Finish Won't Dry
Forum topic by jockmike2 posted 08-07-2010 06:56 PM 4269 views 0 times favorited 7 replies Add to Favorites Watch
View jockmike2's profile
10635 posts in 4452 days
08-07-2010 06:56 PM
Topic tags/keywords: question watching paint dry
Can I mix Japan dryer with mineral spirits and put it on a topcoat of minwax stain/varnish and make it dry. For some reason this topcoat will not dry. All suggestions helpful. Thanks, mike
7 replies so far
View Ger21's profile
Ger21
1075 posts in 3336 days
#1 posted 08-07-2010 11:55 PM
What kind of wood is it on? Some oily woods are known for keeping the finish soft.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
35149 posts in 4606 days
#2 posted 08-08-2010 12:20 AM
Mike I don’t think that mineral spirits will dry. It evaporates.
Try mixing a little bit of your minwax stain with some japan drier and put it in a glass and see if it dries. If it does then try putting a topcoat on top of what you have now,
I use about 1/2 a capful of japan drier to a cup of finish so it you are only mixing up a couple of teaspoons to test don’t use a lot of japan drier. Also you can’t store the mixed finish, so only mix what you need.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
#3 posted 08-09-2010 02:16 AM
Thanks karson. I’ll give it a go.
View sedcokid's profile
sedcokid
2735 posts in 3804 days
#4 posted 08-09-2010 03:47 AM
I have had this problem in the past, but wasn’t smart enough to ask LJ’s for help. You guys are a walking wealth of info.
-- Chuck Emery, Michigan,
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3312 days
#5 posted 08-09-2010 04:14 AM
Mike, I had the same problem with the same stuff. After a week, I wiped it down with thinner, and resanded and used a stain, let dry and went over it with Min wax satin poly. It was for a whelping box for my daughters dog. The dog liked it. Rand
#6 posted 08-09-2010 03:05 PM
Thanks all for the info, you’re right Chuck all you gotta do is ask. It’s always been that way for me. Usually it’s Karson or Dick Cain to the rescue, but always someone, oh yea, Frank used to be an inspiration too. I’d love how he would tell you you’re full of sh*t! mike
View CharlesNeil's profile
CharlesNeil
2457 posts in 4076 days
#7 posted 08-09-2010 10:15 PM
Mike , this is typical of many oil based finishes in hot humid weather, give it a wet wipe with some naphtha, and leave it over night,just wipe it wet, and leave it, the naphtha will not disturb the sticky finish ( stay wet), but it will open it up a little and it will dry it down .. hot weather finishes will skim over, and not dry well,
