wooden ashtray... will it work?
Forum topic by interpim posted 1022 days ago 3134 views 0 times favorited 15 replies Add to Favorites Watch
View interpim's profile
interpim
1115 posts in 1630 days
1022 days ago
I have recently gotten into smoking cigars lately, and have been tossing around the idea of making my own cigar ashtray. I even have a good plan made up in my head for it.
The problem I keep coming up with though, is will it get ruined. The way I look at it, is I am not going to be putting cigars out in the thing… it’s just going to collect the ash that falls off the cigar. I always let my cigar nubs go out on their own sitting in the recess for them, pretty much the hot part sitting in the air.
If you think this can work, what would you recommend I finish it with? preferably I would like something that is easy to wipe clean, and has a hard outer shell to prevent the wood from taking on anything from the ash.
-- San Diego, CA
15 replies so far
View pmayer's profile
pmayer
382 posts in 1237 days
#1 posted 1022 days ago
As long as you don’t fall asleep with a stogie burning in it, I think it should work fine. I would go with a dark wood, like walnut, that didn’t show much of the ash stain. I would finish it with a penetrating oil (such as tung) to bring out the richness of grain, and then top with lots of coats of oil based poly, so its easy to wipe clean.
Good luck!
View paratrooper34's profile
paratrooper34
699 posts in 1124 days
#2 posted 1022 days ago
I agree with Paul….it will be fine if you don’t leave the hot ash touching the wood. I had a wood ashtray that I bought in Afghanistan on my first tour and we used the heck out it for cigars. Never had a burning issue with it. It was a dark wood, but no idea which.
-- Mike
View FWBGBS's profile
FWBGBS
21 posts in 1411 days
#3 posted 1022 days ago
I would certainly think so. All my Savinelli Pipes are made from the burl of the Briar (Erica arborea). With proper seasoning no finish will be needed; on the inside of the ashtray. To season I would use a cigar torch and simply char (carbonize) the top layer of the ashtray’s bowl.
If you can’t acquire good Briar opt for a dense grained wood (e.g.: Oak, Maple, Mesquite, etc.). As you know, the burl of just about any deciduous is pretty rugged stuff.
-- Brad ~ Puyallup, WA : http://www.box.net/shared/gdqnjv14ds
interpim
#4 posted 1022 days ago
my idea in my head is to laminate some walnut(bottom) with some maple… drill holes for where the cigar rests will go, then turn it leaving the half holes there to support the cigars, then sanding the crap out of it to give it an ultra smooth finish to improve cleaning.
-- San Diego, CA
View hairy's profile
hairy
1763 posts in 1704 days
#5 posted 1022 days ago
How about a metal liner? Sheet copper or brass. Just a thought…
-- It must be jelly baby, cause jam don't shake like that...
View David Craig's profile
David Craig
2127 posts in 1280 days
#6 posted 1021 days ago
Another option would be to use those cheap glass ashtrays as a liner for the turning. I did some reading on this recently and FWBGBS’s suggestion on torching the bottom for producing a carbon layer was mentioned on a few sites.
View Dan Lyke's profile
Dan Lyke
1367 posts in 2297 days
#7 posted 1021 days ago
Head to a high end deck place and ask to see their scrap pile. Many of those woods are more fire resistant than concrete.
View knotscott's profile
knotscott
4210 posts in 1547 days
#8 posted 1021 days ago
My thinking was similar to Hairy’s…add some metal and show off just the wood sides. It’s not worth the risk of a mishap and having it catch fire.
View snowdog's profile
snowdog
1117 posts in 2154 days
#9 posted 826 days ago
I never thought of it, why not a wooden ashtray. Wooden pipes don’t burn up :)
View Bill White's profile
Bill White
2608 posts in 2132 days
#10 posted 826 days ago
If you can find a hunk of bois d’arc or mesquite, you’ll have a tray for life. DO NOT PUT POLYCRAPITHANE ON IT!!!!!! Sand it, wet it lightly to raise the grain, sand it again with a finer grit. You know the drill. You want to burnish the wood. I’ve even polished on the lathe with another piece of wood to get the burnish.
Bill
-- bill@magraphics.us
View JLadd's profile
JLadd
5 posts in 836 days
#11 posted 211 days ago
Hi, sorry to resurrect an old discussion, but I was wondering if you ever attempted this project? What stood out to me was I had the same thought you did about drilling rest holes and then turning down halfway through them. I wanted to see how that panned out.
Thanks,
Jonathan
snowdog
#12 posted 210 days ago
I have to try this and see how it works out I. I like the idea of drilling holes for the rests and then turning it. Winter is coming and this would make a great gift (mostly to myself :)
interpim
#13 posted 210 days ago
I did end up turning one out. It came out fairly well, and as long as your not mashing out the butt into the wood, it should hold up for a long time.
When I turned it, I did notice that on the leading edge of the cutouts from where I drilled in there was a little bit of tear out from having no support. I think It might work better next time if I create dowels to fit into the drilled out holes to help backup the edges of the cutouts.
-- San Diego, CA
View jap's profile
jap
1038 posts in 226 days
#14 posted 210 days ago
do you want a new house? :)
jk i don’t know
-- Joel -- http://diversitywoodworks.wordpress.com
View Rockbuster's profile
Rockbuster
110 posts in 780 days
#15 posted 210 days ago
Keep making those ash trays, but give up the cigars. I quit 20 years or so ago, but when ever somebody lights up a good cigar, my nose pays attention. Here is a suggestion, go to your local glass store, and have them cut you some round disks from either 1/8” or 1/4” glass cut them the diameter to fit the bottom of your ash tray. you will still be able to see your fine wood work.
-- Rockbuster,Ft. Wayne,In It is far better to remain silent, and appear the fool, than it is to open ones mouth, and remove all doubt.
