New Kitchen Faucet
« back to Coffee Lounge forum
Forum topic by Jim Jakosh posted 12-12-2016 01:16 AM 811 views 0 times favorited 20 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
21295 posts in 3249 days
12-12-2016 01:16 AM
Topic tags/keywords: tip
This is not a wood topic but it took time away from woodworking and might be useful for someone else.
I put in a new Moen faucet in the kitchen and my wife is not happy with it because the flow rate is half of what it was with the old one. I thought it might be the Shark bite valve I used that was restricting the flow and then LJ Splinterbubba told me that he was told the all the new faucets have a federally mandated low flow rate to conserve water.( I’m still going to use a pot full of water only I have to wait twice as long for it to fill. Great thinking??????? )
I called the plumbing shop in town and asked if they had a flow through aerator to replace this low flow one in the faucet. They said they were all federally conforming to the 2.5 gal/min regulation.
I looked at this green disk ( you might have know they’d make it Green!!!!) with a little o-ring in the center and I plucked it out with my knife and, wallah, I was back to full flow again. Happy wife and back to the shop for more woodworking…................cheers, Jim
20 replies so far
View lew's profile
lew
12320 posts in 3899 days
#1 posted 12-12-2016 01:22 AM
Thanks for the tip, Jim!
View Druid's profile
Druid
1863 posts in 2939 days
#2 posted 12-12-2016 01:31 AM
In my area, I’ve seen the same type of restriction in new shower heads (fixed or the hand-held style).
-- John, British Columbia, Canada
View Andy's profile
Andy
238 posts in 971 days
#3 posted 12-12-2016 02:19 AM
I had the same problem, same brand faucet too. I had not thought that they could have deliberately made the faucet to restrict flow. I will definately be making that faucet a little less green. Thanks Jim!
-- Andy Smith https://www.etsy.com/shop/xrayhardwoods
View Joe Lyddon's profile
Joe Lyddon
10265 posts in 4196 days
#4 posted 12-12-2016 02:24 AM
Yep… they just waste time!
If you want a glass of water, or fill a gallon jug, that is what you want to do… You are going to use That much water no matter what the flow is… It is a very poor mandate / law which has not been properly studied!
It is a waste of time; therefore, technically, bad for the economy! LOL
We got some attachments to replace filters, etc. ... I installed them… They are a PAIN IN THE A$$... I’m about to take’em off and put the OLD back on!!
I’m tired of wasting so much time just to get the water I want to use… and have to wait longer to get it!
Maybe, if Trump was aware of this, he might get it stopped (or try to) ... ??
View BobWemm's profile
BobWemm
2534 posts in 2070 days
#5 posted 12-12-2016 03:04 AM
Pretty much the same thing here in Australia, all the newly built houses have flow restrictors, I took them out of my Daughters rental house.
-- Bob, Western Australia, The Sun came up this morning, what a great start to the day. Now it's up to me to make it even better. I've cut this piece of wood 4 times and it's still too damn short.
View doubleDD's profile
doubleDD
7702 posts in 2187 days
#6 posted 12-12-2016 03:17 AM
Time is precious Jim. Take those things out. They do have their purpose but we can regulate the flow with the handle if we choose.
View diverlloyd's profile
diverlloyd
3106 posts in 2001 days
#7 posted 12-12-2016 03:48 AM
The inlaws had new counter tops put in and a new faucet. Don’t know the brand but it’s a single handle design with the handle on the side. Flow is decent but the damn thing comes loose after a day or two of use. The builder told
them that they all do it. Pretty annoying having to tighten up the one nut under the sink with it’s special wrench. I have been thinking of putting a ring of silicone around the base to see if that helps. Just figured I would throw that out here since this is a fauset thread.
View Roger's profile
Roger
20948 posts in 2948 days
#8 posted 12-12-2016 12:46 PM
Nice tip Jim
Jim Jakosh
#9 posted 12-12-2016 01:30 PM
I’m glad I could help someone out there!! That sure saved my bacon here at home. Carol was wanting to get a new new faucet!!
Hi John, I don’t mind it in a shower head because you can still get a good spray and there is where it is most needed because some people take a half hour shower! I made a restrictor for mine and you don’t even notice it there.
Hi diverlloyd, our new faucet is a tall one hole type and I was really concerned at it staying tight. It has the handle right on top and I love it. It is a Moen and they have a ring with a slot cut in it so you can slide it one over the tubes coming out and then has 3 5/16” screws in that ring that you tighten and it stays put.
On yours, the turning of the faucet must loosen that nut. I wonder if you can put that kind of ring between the nut and the underside of the counter??
Cheers, Jim
diverlloyd
#10 posted 12-12-2016 07:36 PM
Jim theirs looks something like this except it has no base plate.
All it has is the tube that goes through the counter and a single nut with a special wrench and socket to tighten it.
View bonesbr549's profile
bonesbr549
1576 posts in 3211 days
#11 posted 12-12-2016 07:37 PM
All I can think of is Krammer in Seinfield.
diverlloyd
#12 posted 12-12-2016 08:09 PM
Yeah it’s kramerish my father in laws has zero mechanical skill so it always fun to go play handyman over there.
Jim Jakosh
#13 posted 12-12-2016 08:21 PM
I’ll bet the tube coming through is about 1 1/2”. You might go to a plumbing shop and see if they can adapt one of the U shaped washers to it. They have three bolts in them and you tighten up against a flange and in this case it would be the nut. Not sure it can be adapted, but I know ours holds real well.
Also, maybe they make a large shakeproof style washer that could go on before the nut and would resist loosening??
Cheers, Jim
View corelz125's profile
corelz125
542 posts in 1120 days
#14 posted 12-12-2016 08:41 PM
A lock washer the same as a shake proof washer? Lock washers stay pretty tight once it’s tight
Jim Jakosh
#15 posted 12-12-2016 10:18 PM
I see that the external tooth lock washers only go to 1”. That is what I know as a shakeproof lock washer.
http://www.globalindustrial.com/g/fasteners/Washers1/MetricExternal-Tooth-Lock-Was/external-tooth-lock-washers
Jim
