Restoring some chisels, need some help
« back to Hand Tools forum
Forum topic by Marn64 posted 12-11-2016 10:44 PM 1052 views 0 times favorited 16 replies Add to Favorites Watch
View Marn64's profile
Marn64
296 posts in 933 days
12-11-2016 10:44 PM
Topic tags/keywords: question chisel refurbishing
Hey everyone,
So I recently got a set of antique Witherby chisels for a dollar each. They’re a 1/2 in, 3/4 in, 1 in, and 1 1/4 in. the 1/2 inch is so bent that I can’t lap it out, if I did lap it out I wouldn’t have a chisel left. What is the best course of action here, should I take it to a blacksmith to get it straightened out? Second, most of them still have wood from the handle inside them, how should I get that out?
Thanks,
Benjamin
-- Benjamin, Milwaukee
16 replies so far
View Jeff Heath's profile
Jeff Heath
67 posts in 3216 days
#1 posted 12-11-2016 11:23 PM
A chisel bent that badly is going to be tough to straighten out. Whoever does the work is going to have to know how to redo the heat treat on it, as any heat put to it will ruin the temper. It won’t be hard enough after, so it will have to be heat treated again. Not always easy to do.
As far as getting the old broken wood out, drill them out, and if they weren’t glued or epoxied in, they should come out with a few good raps on a piece of hardwood. If they’re stuck good, or glued in, you’ll have to carefully drill/chisel/gouge them out. Clean out the sockets good before installing new handles.
-- Jeff Heath
View Tim's profile
Tim
3812 posts in 2109 days
#2 posted 12-12-2016 02:12 PM
Agree with the above. Short of grinding and lapping you’d have to properly forge and heat treat them. Grinding and lapping would probably be easier, but you’ll have to be careful about overheating when grinding. Or if you know a machinist, you could have them set it up on a surface grinder.
And drilling out the wood should work fine. If they are glued or epoxied, some careful heating will release either. About 400-500 degrees will release most epoxy, wood glue less. Clamp the cutting end on whatever larger piece of metal you have to act as a heat sink or keep it in water.
View mike02130's profile
mike02130
170 posts in 820 days
#3 posted 12-12-2016 03:19 PM
Pictures please.
-- Google first, search forums second, ask questions later.
Marn64
#4 posted 12-12-2016 10:15 PM
Here is the offending chisel….
mike02130
#5 posted 12-12-2016 11:07 PM
I would just leave it alone. Still works fine?
View Loren's profile
10477 posts in 3795 days
#6 posted 12-13-2016 12:33 AM
That’s an extremely thin profile. Does it match
the other chisels?
Marn64
#7 posted 12-13-2016 01:24 AM
That s an extremely thin profile. Does it match
the other chisels?
- Loren
It does match the others in profile (accept for the bend), though each ascending chisel is thicker than the last. This is the thinnest, the 1 1/4 chisel is the thickest. All the others are straight as an arrow. I found them as a set by the way.
View bbasiaga's profile
bbasiaga
1240 posts in 2142 days
#8 posted 12-13-2016 03:21 AM
you might find you like that mini swan neck for paring. Is it pretty straight from the edge to the kink? If so that bend will keep your hand a little ways up away from the work when paring.
Brian
View Tim's profile
Tim
#9 posted 12-13-2016 03:31 PM
Yeah, that’s not going to be flattened by grinding. I’d also sharpen the last inch and try to use it that way.
View Downwindtracker2's profile
Downwindtracker2
2 posts in 710 days
#10 posted 12-15-2016 08:49 PM
I have straightened chisels, sometimes in a vise, sometimes with a urethane deadblow hammer on a piece of steel.. Someone bent it using it as pry bar, why shouldn’t it bend back? Most tempering on old chisels doesn’t go all the way up.
-- man of foolish pursuits
#11 posted 12-15-2016 09:19 PM
I can’t really tell from the picture what the
back is, but in truth you normally only
use the end of a chisel so while the bend
is aesthetically annoying, in actual sharpening
for usage it’s no big deal since you only
need to flatten the back inasmuch as
that portion of the back affects the edge.
I also agree with Downwindtracker. I think
you could straighten the chisel using similar
methods.
Marn64
#12 posted 12-16-2016 08:00 PM
I had no luck bending it out by hand, though I did have an idea, why not use a forge press like so?
mike02130
#13 posted 12-16-2016 08:02 PM
Why so concerned? Accept it, figure it out or put it in a drawer.
View Logan Windram's profile
Logan Windram
347 posts in 2609 days
#14 posted 12-16-2016 09:10 PM
that half incher is what I like to call a doorstop…. get the other ones tuned up, buy a nice LN 1/2” chisel and make it a day….
mike02130
#15 posted 12-17-2016 04:11 PM
Here is a hail Mary idea.
I’m not a metal worker but from my experience, steel either bends or snaps. It has spring to it, that is why putting it in a vise or hitting it with a hammer won’t straighten it out. To straighten it out, I believe it needs to be over bent and it may spring back to straight. Your drawing above gave me the idea. Try it out and let us know if it works or not. I have some Witherby chisels and they are excellent.
