Broken Delta Table Saw
Forum topic by Knowshowrosegrows posted 12-11-2016 07:04 PM 551 views 0 times favorited 2 replies Add to Favorites Watch
View Knowshowrosegrows's profile
Knowshowrosegrows
3 posts in 785 days
12-11-2016 07:04 PM
Topic tags/keywords: motor repair tablesaw question
Hi, I am a new woodworker who has been setting up a woodshop. I have a fairly new (March 2016) Delta table saw. I was cutting some thin wood and the motor stopped moving and started humming.
I tried tapping it with a hammer, pushing the reset button while it was running (humming), plugging it into a different circuit.
I know NOTHING about motors. I’m not sure what to do next.
2 replies so far
MrUnix
6941 posts in 2345 days
#1 posted 12-11-2016 07:45 PM
Probably an easy fix and there are several things you can test to determine the problem, but since it’s new, it should still be under warranty. Best bet would be to just have it fixed/replaced under warranty. If that isn’t an option, then we can shift to how to test and find out what is wrong.
View WhyMe's profile
WhyMe
1053 posts in 1707 days
#2 posted 12-11-2016 09:30 PM
Delta has a 5yr warranty. Are you the original owner?
