Blanket chest question
Forum topic by bigdog72 posted 238 days ago 174 views 0 times favorited 6 replies Add to Favorites
View bigdog72's profile
bigdog72
12 posts in 261 days
238 days ago
I am considering making a blanket chest for LOML. I have found the plans for the one I want and it is a raised panel design. The widest board in the cut list is 5 1/2”. The one I am looking at is made with pine. Is there any reason why I couldn’t use cherry instead?
-- Geoff, Lillington, NC
View mot's profile
mot
4839 posts in 488 days
238 days ago
There is no reason you can’t use cherry. If you can’t find stock that wide, do a panel glueup and make one that wide. You can really add an original component of what looks good to your eye. Go for it. As much as many like working with pine, I prefer harder woods. Good luck with it, and be sure to blog it!
Cheers!
View GaryK's profile
GaryK
8414 posts in 440 days
238 days ago
No reason what so ever why you can’t use another type wood.
12741 posts in 852 days
238 days ago
Go for the cherry. It will look so much bettter.
View Betsy's profile
Betsy
1760 posts in 348 days
238 days ago
Geoff, I have a solid cherry blanket chest at the end of my bed. Cherry makes a wonderful piece. The only thing to remember with cherry is that it can burn easy when you cut it. So make sure your blades are sharp and keep your feed rate steady. Also remember that Cherry can darken with age and exposure to sunlight. My blanket chest is just now starting to darken a bit and it’s quite pretty.
Like Tom said – if you can’t find the right width pieces do a glue up to make them that wide.
With all that said, I’ve seen some very nice pine ones done. If you go with pine, you might try knotty pine as that looks nice.
-- Betsy - GO BUCKS!
View rikkor's profile
rikkor
7202 posts in 326 days
238 days ago
Go for the cherry!
-- Maplewood, MN
View Chiefk's profile
Chiefk
38 posts in 223 days
222 days ago
About 1 year ago I built a blanked chest with raised panels. It was a good learning experience for me. However, there are many things I would do different should I build another one. Depending on your experience level, you may want to build a prototype out of a less expensive wood such as pine. I believe this will enable you to work through the different processes in the construction of the chest. Which should result in a much better blanket chest for your wife. Chiefk
-- P Kennedy Crossville, TN
Bookmark And Share This Page
