Help trueing a crosscut sled
Forum topic by toddbg posted 12-10-2016 06:18 PM 644 views 0 times favorited 5 replies Add to Favorites Watch
View toddbg's profile
toddbg
26 posts in 1610 days
12-10-2016 06:18 PM
I recently made a crosscut sled and I am at the stage of trueing the fence 90 to the blade.
I was using the “5 cut method” and have been having a heck of a time getting this correct.
I could use some advice/double checking my math and whether I need to make additional adjustments.
For the last correction I came up with the following:
A= 1.0615”
B= 1.0440”
Length of cut= 10.6875”
A-B= .0175”
.0175”/4= .004375”
.004375”/10.6875”= .00040936”
Is this good?
If I need to adjust I get:
.00040936”x28”= .01146199 = ~.00115”
Does the adjustment move back towards me or forwards towards the rear fence?
Thanks for the advice.
Your guys help is much appreciated.
-- -- Todd, Washington
5 replies so far
View bbasiaga's profile
bbasiaga
1231 posts in 1988 days
#1 posted 12-10-2016 06:57 PM
You’re only off .004 in 10”, or .0004 per inch. Others will tell you you can make it better, and you can, but i wouldn’t bother.
Whether you have to move your fence forward or back depends on which was the thick end. Looks like you are thicker at the front (end away from the fence), so that means you’d move the left side of the fence away from the rear fence. (I think I’ve visualized that right).
When I made my first one, I chased perfection until I was ready to quit wood working all together. When I made the second one, I got results similar to yours and have been very happy with it as well as glad I didn’t waste the time messing with it.
Brian
View ArtMann's profile
ArtMann
939 posts in 809 days
#2 posted 12-10-2016 07:24 PM
I have been down this same road so many times. I kept trying to micro adjust my sled fence many times to get it close to zero and I just never could. Finally, I tried doing the same measurement several times without changing anything and I came up with a variation between successive measurements that is larger then the total error I had calculated the first time I did it. The truth is that the kind of error you are talking about can be accounted for with the natural variation in an inherently variable mechanical system. It is hopeless to repeatedly get that kind of accuracy with wood and woodworking tools.
In practical terms, 0.0004 inches per inch is completely irrelevant in terms of building something with no cracks or defects. You are likely to make cuts that will totally dwarf this kind of error and never even notice it.
View Rich's profile
Rich
2790 posts in 582 days
#3 posted 12-10-2016 07:29 PM
I agree with Brian that you’re close enough. For reference, if you’re following William Ng’s method exactly, then if your error is positive, move the fence back, and if it’s negative, move it forward.
-- No matter how much you push the envelope, it'll still be stationery.
toddbg
#4 posted 12-10-2016 08:18 PM
Thanks everyone!
I was just getting confused if my cutting error was .004 or .0004.
Four thousands over 10” isn’t too bad. :)
View HokieKen's profile
HokieKen
4947 posts in 1131 days
#5 posted 12-11-2016 12:19 AM
Yep. You’re good :-)
-- Kenny, SW VA, Go Hokies!!!
