Question about warped slab. PLEASE HELP
Forum topic by BrutDesign posted 12-09-2016 10:43 PM 1060 views 0 times favorited 12 replies Add to Favorites Watch
View BrutDesign's profile
BrutDesign
5 posts in 652 days
12-09-2016 10:43 PM
Topic tags/keywords: slabs slab question advice help please maple walnut cherry milling finishing joining modern nakashima maloof
Hello there,
This is my first time posting anything on this website though I have pretty consistently been directed here for advice.
I am a young professional woodworker… Have had my own studio for only about a year and a half.
This question is about a large dining table slab. First off…. This is not a question about how to flatten a slab. I can do that.
I bought this maple slab from Keim Lumber in Ohio and it was shipped to me in Vermont. Now, the slab is advertised as being flat and thickness sanded. If it’s not flat, why not sell rough lumber? I was suspicious to begin with that it would actually be flat, and of course I could tell the minute the tractor trailer unloaded it that it was warped… Again, I was really, really hoping that it wouldn’t be, but it was. It has been in my shop for about two weeks.
Here is my question: The table is warped so that if three corners are touching a flat surface the warped corner is slightly less than 1/2” elevated from the flat surface. Or, if you split the difference, two opposite corners would be elevated by a quarter inch. So okay… now my actual question: Is that acceptable for a finished table top??? Without a doubt it would not affect its functionality, but I can definitely see it.
Everyone’s opinion would be valid and appreciated, but I am hoping that someone with professional experience working with slabs might tell me their allowance for defects like this. I would really like to avoid going through the process of flattening it with a router.
I guess the final consideration is that the base is two bronze “trestle” bases and they will me mortised into the bottom… so I can shim under them without it being glaringly obvious.
Posted some photos below. Some angles the warp is totally obvious, in others it is less so.
Thanks in advance for your help.
Best,
G
-- Gerard Williams, Founder: Brüt Design
12 replies so far
View Bill White's profile
Bill White
5050 posts in 4079 days
#1 posted 12-09-2016 10:50 PM
How long have you had the slab, and have you allowed it to equilibrate in the shop environment?
Big slabs such as yours will require some time to “settle”. After that, they will need to be hand planed. Even then they will wiggle more.
You’re in for some time and effort.
If you’ll PM me, I can give you a name of an excellent woodworker who may be able to help with your challenge.
No guarantees for sure, but he might be able to offer some wisdom.
Bill
-- bill@magraphics.us
View DirtyMike's profile
DirtyMike
637 posts in 1021 days
#2 posted 12-10-2016 03:47 AM
Is that a 3000/5000 watt heater i see?
View canadianchips's profile
canadianchips
2602 posts in 3116 days
#3 posted 12-10-2016 02:47 PM
Beautiful slab !
Downside: Unfortunately solid wood moves with change in humidity..”moisture”.
You may end up with cracks andchecks as well as time goes on !
If your clients are aware of this it wont be much of an issue.
You might be able to make “kerf cuts” on the underside to relieve the movement.
The market here…..people are actually looking for tables with some imperfections…...they think its character !
If it were my build….I would try to make it as flat as possible in my shop…..what happens after is the clients !
View mahdee's profile
mahdee
3971 posts in 1886 days
#4 posted 12-10-2016 03:27 PM
The only remedy I have used is to put a 1” blocks on the sides that touch and one on the middle, clamp the other two sides so they go below 1”. Every few days relieve the pressure and see if it has corrected itself. It looks like the slab is about 2” thick. If so, it should work out fine.
-- earthartandfoods.com
View JoePowers's profile
JoePowers
3 posts in 652 days
#5 posted 12-10-2016 03:35 PM
Without battens screwed to the underside or breadboards pinned to the ends I think that degree of warping is to be expected. The good news is that you may still be able to pull the table top flat with battens or bread boats and it should remain fairly flat thereafter. I’ve used these reviewing several times.
View MNgary's profile
MNgary
303 posts in 2536 days
#6 posted 12-10-2016 04:49 PM
To answer your question, BrutDesign, a DR table with one corner more than 1/32 inch higher than the other 3 would press my standards as being acceptable. I personally think most customers would not notice 1/64 and would make it so—even a live edge slab.
-- I dream of a world where a duck can cross the road and no one asks why.
BrutDesign
5 posts in 652 days
#7 posted 12-11-2016 02:16 AM
- DirtyMike
Yes it is. Is that good or bad? haha. I didn’t know that heater had any fans
BrutDesign
5 posts in 652 days
#8 posted 12-11-2016 02:19 AM
- MNgary
Thanks for your input. That is quite an exacting standard, but it is good to set the bar high! It’s looking like I’m going to have to flatten the friggin’ thing. Would have been nice to just clean the edges, sand with 220, and finish.
BrutDesign
5 posts in 652 days
#9 posted 12-11-2016 02:20 AM
Without battens screwed to the underside or breadboards pinned to the ends I think that degree of warping is to be expected. The good news is that you may still be able to pull the table top flat with battens or bread boats and it should remain fairly flat thereafter. I ve used these reviewing several times.
- JoePowers
Battens are a good idea but I don’t think it goes with the look of the table!
BrutDesign
5 posts in 652 days
#10 posted 12-11-2016 02:24 AM
Beautiful slab !
- canadianchips
Thanks! yeah, once it leaves there is really no telling what will happen. It’s a little bit hard to explain that to people with no experience with wood/wood movement, but I suppose they’ll learn! Interesting idea with the kerf cuts. I’ve never heard that.
DirtyMike
#11 posted 12-11-2016 03:25 AM
- DirtyMike
Yes it is. Is that good or bad? haha. I didn t know that heater had any fans
Hopefully good, I am still waiting for mine to ship. Sorry i am no help with your slab troubles, I feel you pain. Like others have said slabs move and it is very frustrating. good luck and welcome to lumberjocks
- BrutDesign
View JBrow's profile
JBrow
1366 posts in 1039 days
#12 posted 12-11-2016 03:51 AM
BrutDesign,
I suppose the question as to whether a top ½” out of flat is good enough to pass on to a client goes to whether this would be acceptable to the client and perhaps more importantly, to whether it meets your personal standards. But since you are asking whether a ¼” out of flat on two corners is good enough and your other comments, I suspect this slab does not meet your standards.
My guess is that at some point the slab was flat as advertised. But since then it has been improperly stored so that air could not circulate freely around the entire slab. I doubt that any effort to mechanically force the slab to flat will work. It is my belief that the forces in the wood are too great to be overcome mechanically. If the slab has been properly stored since arriving in your shop and remains warped, I can think of three ways to bring the slab back to flat.
The first is a lot of planing and sanding, which would reduce the thickness of the slab by ½”. This would be a lot of time and effort with pretty much guarantee unacceptable results; a flat but thinner slab.
The second option is canadianchips’ kerf method. While deep enough kerfs would allow the slab to flatten out with mechanical fasteners or mortises and glue, saw kerf cuts visible on the ends could be unacceptable. If the kerf cuts are made with a core box router bit, the kerfs would look nicer on the ends. The photos are of outdoor tables where I added core box bit kerf cuts 1/3 of the thickness of the top deep on the lower side of the tops. These were added to keep the originally flat tops flat; not make warped tops flat. In your case the depth of the kerfs may need to be a little deeper. Hopefully there is enough detail visible to show how this style of kerf cut look.
End table,up side down…
Coffee table with core box kerfs showing on the end…
The third method is to rip the slab into narrower boards, joint the edges, and glue the slab back together. But this method has its risks. If stresses exist in the slab, ripping free narrower planks could result in twisting and warping. Warping or twisting of individual planks could require face jointing and planing. Even if the method is successful, the width of the slab would be reduced by the total of the amount removed by ripping and jointing.
Long tapered maple shims could be noticeable, but without knowing more about the base and the method for attachment, it is difficult to say whether shims would be acceptable. Mortising the top to the metal base seems to me could impede wood movement and if so, could result in the top cupping or cracking.
