Cutting out design on 2ft x 4ft pine
Forum topic by roughcuts posted 12-09-2016 09:54 PM 662 views 0 times favorited 5 replies Add to Favorites Watch
View roughcuts's profile
roughcuts
18 posts in 658 days
12-09-2016 09:54 PM
I have a design i will be transferring to a 2ft x 4ft piece of pine 1/2” thick. My plan is to draw it out, and then cut it with skill saw + straight edge. If i do that, will the material removed from the blade cause my pieces to all go out of whack? I need them to fit together fairly snug. My jigsaw just wasn’t cutting straight enough to want to use that. That blade was wandering even with a straight edge. The cuts are all straight, no curves or anything.
Thanks for your help
5 replies so far
MrUnix
6887 posts in 2315 days
#1 posted 12-09-2016 09:58 PM
Depends entirely on what you are trying to do… but it will remove wood, the thickness of your blade. If that will cause things to go ‘all out of whack’, you need to be more descriptive of what you are trying to cut – maybe post a picture of the design or something.
View Richard's profile
Richard
1920 posts in 2807 days
#2 posted 12-09-2016 10:15 PM
A Band Saw if you have one will take less wood out than circular saw would . Plus you need to remember that with a circular saw you need to be careful of over cutting the corners if there are any.
roughcuts
#3 posted 12-10-2016 02:01 PM
is there a type of skill saw blade that wont wander as much? I could use a straight edge with it to keep it as straight.
roughcuts
#4 posted 12-11-2016 12:16 PM
Below is a quick sketch of what I plan on cutting out. Im not worried if the outside edges don’t line up as i can clean them up after
View Mark Shymanski's profile
Mark Shymanski
5622 posts in 3829 days
#5 posted 01-09-2017 10:45 PM
Is any of that waste material, or do you need to reassemble it to look the same way? What are you trying to make?
