Engage brain before troubleshooting router troubles!
Forum topic by Mark Shymanski posted 08-05-2010 11:48 PM 2059 views 0 times favorited 10 replies Add to Favorites Watch
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3741 days
08-05-2010 11:48 PM
Topic tags/keywords: humor tip router trouble shooting
Some days I wonder why they let me wander around loose. I have a Triton router which I am inordinately pleased with, and have been having a great time this first week of my vacation working on panel and frame doors for some renovations Jenn and I are doing at the house. The Triton has a very clever lock out system that will not let you start the router until you slide back a plastic bezel and turn the power on, it is also clever in another way which I learned the hardest way possible (and I’ll get back to that in a bit) ;-)
So I have the router upside down in my table and I am beavering away making sawdust and generally enjoying actually making something in my shop. Went inside for lunch, came back and wanted to move onto another stage of the project so I needed to change router bits…no problem (so I thought)I unplug the router (safety first right!) crank the little through the table crank and bring the collet up to undo and chunk it stops! I crank it down again check it there if are bits of wood somehow stopping it’s upward progress…nope all clear but there is sawdust all over the place so I take the plate up and blow out all the dust. Try cranking it again…no joy it stops again. To make a long and embarrassing story somewhat shorter I eventually take the plate off, two top plastic housings off remove the snap ring from the crank assembly and pull the plunge base off (thinking I somehow stripped the crank assembly), came in read LJ’s to see what other problems people had reported with the Triton router all to no avail. I just could not get the collet out far enough to get the wrench on it. Then I looked up into the mount for the non-cranked support post…there was a strange plastic cube that seemed to be the same size as the distance I could not crank the collet…remember that plastic bezel I was so please about stopping me from switching on the power at the wrong time, well it also prevents you from cranking out the collet whilst the power is turned on! Really good engineering…really bad trouble shooting on my part! I had neglected to turn the power switch of the router OFF because I was using the switch on my router table to turn the router off and on, so of course the safety feature that prevents idiots like myself doing grievous injury to themselves was behaving exactly as it should!!!
I sheepishly reassembled my router, before Jenn (or anyone) came in the shop and noticed what a klutz was working there. I have now finished my first ever frame and panel door; of which I am very pleased but my ego is still suffering badly :-)
10 replies so far
View darinS's profile
darinS
709 posts in 2896 days
#1 posted 08-06-2010 12:24 AM
Sounds like something I would do. Unfortunately for me, LOML would catch me in mid problem solving, then I would never hear the end of it.
-- They say many people die because of alcohol. They never realized how many of them are born because of it.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3144 days
#2 posted 08-06-2010 12:25 AM
thank god its only your ego that has been heart
and nothing ells
just a shame powertools ain´t build so people can´t do anything on them
with out the powerswitch is of and the power is disconnected
congrats with your door hope it will be abused many years and hold up to it :-)
Dennis
35126 posts in 4429 days
#3 posted 08-06-2010 12:45 AM
Nice of you to share your agony. So we can smile at us never having done it.
But, I’m sure a few will.
View jim C's profile
jim C
1472 posts in 3127 days
#4 posted 08-06-2010 01:00 AM
I have the same router installed under my router table. The first thing I did was to remove that plastic piece of S*&^%.! If I were using it as a hand router, it would almost render it impossible to use. As I have a regular on/off switch, there is no need for it.
Rick Dennington
5913 posts in 3223 days
#5 posted 08-06-2010 01:00 AM
Greetings Mark,
AAAAHHHH yes, the old router…don’t you just love’em….
Any brand, all sizes, shapes, and different colors…...they are just like any other tool…..
They can leave you scratching your head, wondering how this or that happens, and most of the time
it’s what you did (or we do) that makes it happen. We all get a little off plumb sometimes….. lol.
View Gene Howe's profile
Gene Howe
10548 posts in 3457 days
#6 posted 08-06-2010 01:07 AM
Well, I’ve never done ANYTHING like that!
How about putting on a band saw blade with the teeth pointing up. Getting angry at the supplier for sending me a screwed up blade. Calling customer support and having the girl explain that I needed to twist it inside out.
And, they still let me vote and drive.
View Gregn's profile
Gregn
1642 posts in 3012 days
#7 posted 08-06-2010 04:45 AM
I’m glad I’m not the only one here who has had the light bulb come on.
Mark Shymanski
#8 posted 08-06-2010 04:53 AM
Thanks guys, it’s nice to know I am not alone LOL!
View Napaman's profile
Napaman
5526 posts in 4106 days
#9 posted 08-06-2010 05:46 AM
ouch…but a bruised ego is waaaaay better then a missing body part…good story…
-- Matt--Proud LJ since 2007
Mark Shymanski
#10 posted 08-06-2010 06:21 AM
Yeah, there was not danger as I had the thing in pieces…unless I swallowed one of them I guess LOL!
