Key hole jig.
Forum topic by Abn101mp posted 12-09-2016 08:40 PM 681 views 0 times favorited 4 replies Add to Favorites Watch
View Abn101mp's profile
Abn101mp
51 posts in 618 days
12-09-2016 08:40 PM
Looking for ideas for a key hole jig I can use for small shelves I am putting up in our spare bathroom.
Any suggestions would be a help.
-- Dan,Mid-Maine
View Jim Finn's profile
Jim Finn
2658 posts in 2947 days
#1 posted 12-09-2016 11:16 PM
I have just put the key-hole bit in my table mounted router and using a fence and right and left stops, made the keyhole slot needed.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View joek30296's profile
joek30296
53 posts in 2892 days
#2 posted 12-10-2016 07:22 PM
You can do as Jim said, use a keyhole bit in a router or purchase keyhole hangers that screw on. The hangers are available at most big box stores or even Wally World. A pack of 10 is less than $6.00.
-- "There are two theories to arguing with a woman....neither of them work"
View JBrow's profile
JBrow
1361 posts in 946 days
#3 posted 12-11-2016 04:12 AM
Abn101mp,
I use Jim Finn’s router table method. But a keyhole router bit is typically small and a lot of material removal is required. Routing the slot first with a straight bit and then perfecting the keyhole with keyhole bit saves some wear and tear on the keyhole bit. However, since this method requires changing bits, care is required to ensure the straight bit set up and the keyhole bit setup are identical. Clamping registering blocks to the router table so that the router fence can be re-positioned exactly where it needs to be after installing the keyhole bit can be helpful. Ensuring the height above the table of the straight bit and keyhole bit are the same can be achieved by using a setup block. A slot (or better yet, a rabbet) routed with the straight bit in a scarp of wood before changing router bits can then be used to set the height of the keyhole bit.
View Greg the Cajun Wood Artist's profile
432 posts in 968 days
#4 posted 12-11-2016 05:49 AM
I bough this template from Rockler and it works good
-- Wood for projects is like a good Fart..."better when you cut it yourself"
