My first table saw needs refurbishing.
Forum topic by AnnaEA posted 08-05-2010 04:50 PM 10992 views 0 times favorited 10 replies Add to Favorites Watch
View AnnaEA's profile
86 posts in 2785 days
08-05-2010 04:50 PM
Topic tags/keywords: question tablesaw repair refurbish sawkillers
My FIL is giving me a tablesaw. It’s the first one I’ve ever had, and it looks pretty old and beat up. It’s a Rockwell 10” Homecraft, and I’ve hunted around and gotten myself the manual and parts list. (All hail OWWM!)
The saw arrives in my basement Monday, where I will start the process of trying to figure out how the dickens the thing works, what kind of repairs and stuff it needs, and how to do all this.
So, while I welcome any general thoughts and advice on this, I do have one serious question right up front.
What are the saw killers? What kinds of problems could a table saw have that would make it not worth repairing?
-- Work hard, play hard, drink good beer.
10 replies so far
View Joe Watson's profile
Joe Watson
316 posts in 3476 days
#1 posted 08-05-2010 05:22 PM
if the top is warped that’s an issue you cant really fix but most others are fixable.
-- Got Wood?
View TheWoodNerd's profile
291 posts in 3121 days
#2 posted 08-05-2010 05:29 PM
Given the cost of parts, I would think that just about any non-trivial repair will make it more viable to buy another quality used saw instead of repairing this one.
-- The Wood Nerd --
View justinwdemoss's profile
148 posts in 2824 days
#3 posted 08-06-2010 02:30 AM
I don’t know your specific saw, but have seen a lot of Rockwell homecrafts on craigslist over the last year. This may not pertain to you as you mentioned that OWWM was one of your consulted sources, but some of the Rockwells are direct drive. If the motor is shot or in bad shape, there really isn’t much you can do or should do. However, if the motor is a belt driven type, the blade can be squared, the fence can be aligned, and the top is dead flat, you can to a lot with an old saw. I love to save old tools and in the past two years have refurbished a 1956 delta RAS and a 1946 Duropower shaper. Good luck and take your time.
Consider posting model numbers and pics. They will go a long way to getting people to be able to help you.
Justin in Loveland, OH
-- Justin in Loveland, OH
#4 posted 08-06-2010 03:30 AM
As soon as it’s into my space I’ll be able to get to the motor and such to get the model number and some decent photos. I think it’s the model 34-660, just from what I could see looking at it through the stuff piled around it, but I won’t know for sure until I can get a closer look. Should be belt driven, if I pegged the model correctly
The omens are favorable though – I was able to prop a level on the edge of the table, and it didn’t look too out of kilter. It’s on a dirt floor right now though, so we’ll see. And the top isn’t aluminum—it’s got some pretty nice looking rust on it, though not so bad it’s pitting or anything. Just a sheen, probably from being in the damp in that shed.
Joe Watson
#5 posted 08-09-2010 04:35 PM
#6 posted 08-09-2010 04:43 PM
Almost exactly, Joe. The name plate on mine says “Homecraft Model 10 Saw”. Otherwise they’re identical in visible details.
#7 posted 08-09-2010 09:39 PM
Okay, I have to take that back – mine does say 10” Homecraft Saw. I got a good look at it today when we went to pick it up. It is a 34-660, per the model/serial plate. It needs re-wiring though, and some repairs under the table where bolts are messed up. My FIL is keeping it to rewire, and I should be able to get it when he is done with the electrical.
View Newbiewoodworker43's profile
150 posts in 2372 days
#8 posted 03-05-2014 02:02 PM
Anna, Did you ever get your table saw up and running? I am looking at the same saw for $50 on CL and was wondering how you like your table saw. Also, was fixing it up worth it or would you buy something newer if you had to do it over?
-- ---Howard, Amesbury MA
View HerbC's profile
1726 posts in 2789 days
#9 posted 03-05-2014 07:51 PM
Look’s like Anna has probably dropped out of active status. Her last post here was 1014 days ago…
-- Herb, Florida - Here's why I close most messages with "Be Careful!"
View SCOTSMAN's profile
5851 posts in 3514 days
#10 posted 03-05-2014 09:18 PM
That’s not so long She’s probably just having a cup of coffee or on the loo.These things take time.Alistair
