How soon to spray shellac over gel stain?
Forum topic by Biruski posted 12-09-2016 12:57 AM 1375 views 0 times favorited 3 replies Add to Favorites Watch
View Biruski's profile
Biruski
2 posts in 590 days
12-09-2016 12:57 AM
Topic tags/keywords: shellac
Hi there. I am staining some raw wood cabinets made of alder. I am using General Finishes gel stain in Georgian Cherry. I used a shellac/denatured alcohol mix as a sealer before putting on 3 coats of the gel stain.
Woodcraft cautioned me that the GF gel stain sometimes “lifts” when you apply the top coat and to prevent that, advised that I spray on some dewaxed Bullseye shellac over the gel stain before I apply the urethane top coat.
Does anyone know how long I should wait after applying the 3rd gel stain coat before I can spray on the shellac? Is a single light spray sufficient or is there any value to several light coats of shellac between the gel stain & the urethane?
3 replies so far
View mrbob's profile
mrbob
182 posts in 625 days
#1 posted 12-09-2016 01:11 AM
When the third coat is dry, since temp and humidity affects that and no info on that, at least 24 hours and wipe wit a rag to see if you get any to wipe off, if so it isnt dry. You could do 2 with a light buffing/ sanding after the first one, green pad or 320, lightly!!! Again, what is lightly on your spraying??? Real subjective!!!
woodbutcherbynight
5290 posts in 2465 days
#2 posted 12-09-2016 03:01 AM
I agree with testing by wiping with a rag and if anything comes off it is still wet. Once dry to this spec wait say a week. What’s the rush? Let the stain cure. Can’t hurt to wait and waiting too long is much better than applying a finish only to have issues.
You see this alot with people using epoxy. Sure it is dry to the touch in a short time but it takes time to cure. If done right it works well. Rush it and issues come up, usually at a bad time.
Biruski
2 posts in 590 days
#3 posted 12-11-2016 07:14 PM
Thanks Mrbob, you’re right it’s difficult to quantify “lightly.”
Alternatively, is there a need for anything beyond one coat of shellac? Again, my goal is just to prevent lift, I’m going to put urethane on top of it.
