Wilton Vise Question
Forum topic by CL810 posted 08-05-2010 03:18 AM 6427 views 0 times favorited 3 replies Add to Favorites Watch
View CL810's profile (online now)
CL810
3835 posts in 3109 days
08-05-2010 03:18 AM
Topic tags/keywords: wilton vise
Does anyone recognize this Wilton vise? I went to their website and they no longer show it. Looking at it, it appears that you could mount this so you could have a face vise and leg vise. Is that right?
Either orientation in mounting it there are only two mounting bolt hole into the workbench top. The other two mounting holes would be at 90 degrees. In the photo below you can only see one of the mounting holes; the other is directly behind the back plate.
The sliding stop can be moved to the other side. Any help with this is appreciated!
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
3 replies so far
View jusfine's profile
jusfine
2422 posts in 3046 days
#1 posted 08-05-2010 03:42 AM
Never saw one of those before.. interesting.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Monte's profile
Monte
4 posts in 2679 days
#2 posted 05-26-2011 03:33 AM
I think I have the same vise.
Dose it have the number 161137-10 on the stationary jaw? Mine also has 161072-10 on the handle, but I think this casting was used for other models as well.
On a 2 1/8 thick work bench, yes, you could use only two holes.
But by adding 2 1/8 blocking under the work bench, you can use all four.
-- Monte, Washington, DC
View bubinga's profile
bubinga
861 posts in 2788 days
#3 posted 05-26-2011 04:49 AM
You will find a lot of info here, about vises and mounting ,http://www.workbenchdesign.net/index.html
-- E J ------- Always Keep a Firm Grip on Your Tool
