sealing the buried part of posts with tar?
Forum topic by Tim_456 posted 08-05-2010 12:16 AM 88603 views 0 times favorited 31 replies Add to Favorites Watch
View Tim_456's profile
Tim_456
170 posts in 3651 days
08-05-2010 12:16 AM
Topic tags/keywords: question cedar
i’m building a wooden screen for some privacy around my deck. Part of this will include two 4×4 Cedar posts that will be set 3-4 feet in the ground. I’ve had some success by putting in the crushed limestone around posts rather than concrete. I saw a This Old House or New Yankee workshop where they dind’t use concrete they used the crushed stuff.
Anyway, I just sealed my driveway with some tar-paint substance that looks fairly waterproof and I’m wondering if slathering some of that on the bottom and lower sides would a good way to seal the part of the post that’s below ground.
Any thoughts on if this is worth the time and aggrevation and if it will make things better or worse in terms of rot.
Thanks,
T.
31 replies so far
View Dan Lyke's profile
Dan Lyke
1520 posts in 4181 days
#1 posted 08-05-2010 01:01 AM
I don’t know what the current thinking is, and I don’t have any actual facts to bring this conversation, but…
When I was growing up out in the middle o’ nowhere, the common wisdom was that you never set your fence posts in concrete because that’d form a cup that would hold water; the reason for using gravel was to let the water flow away from the bottom of your fence post.
So, in any attempt to try to keep the water away from the bottom of the post, I’d be concerned that I’d be creating a cup that would collect any water, even if it’s just higher humidity flowing internally to the post itself, and keep the bottom of the post wet all the time.
However, I don’t have any tests that’d tell me one way or the other, and I don’t know how one would get actual facts in a process like this ‘cause… well… I need to replace the fence at my house and so far as we can tell it’s 50 years old. And there’s lots about it that was done in ways that I think are wrong. So I don’t know either.
View jusfine's profile
jusfine
2422 posts in 2982 days
#2 posted 08-05-2010 01:06 AM
Slather away!
I have installed quite a few posts, and you will do no harm in using a water resistant finish.
I would suggest cutting the bottom of your posts so they are not a square cut, then slather them.
Bevel all 4 sides at 45 degrees so you have a smaller flat spot on the bottom.
Old timers told me this over 25 years ago, I installed all my fence posts for our farm with tamping them and no concrete, and they are still holding up well.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Gregn's profile
Gregn
1642 posts in 3040 days
#3 posted 08-05-2010 01:40 AM
It was a practice before pressure treated wood to cover the in ground portion with tar to prevent rot.
View Knothead62's profile
Knothead62
2584 posts in 3017 days
#4 posted 08-05-2010 02:03 AM
This might sound goofy but my father was a farmer for many years. He swears that this is true. Never set posts in the full moon. A local guy experimented with some fence posts. The ones set in the full moon actually sank a bit in the ground. Your inquiry is a valid one and I think Gregn is right on the money. Lots of tar.
View pawpawsteve's profile
pawpawsteve
16 posts in 3046 days
#5 posted 08-05-2010 02:27 AM
The primary place that posts rot is at ground level and slightly below. I know this from experience of having posts that I set anywhere from 10 to 15 years ago. Some I set in concrete and some I just tamped in. The ones set in concrete have, every one of them, broken at ground level leaving me to dig up a whole sack of concrete and post so I could put in a new post.
Now when I set posts I put a collar around the post about six inches above and six inches below grade. This can be paint or tar, I use roofing tar as it is cheap and I usually have some on hand for repair jobs. I don’t try to cover the bottom of the post as (in theory anyway) this will trap moisture in the post.
I agree with using the crushed stone as fill rather than concrete as it allows drainage and it should be under the post as well so that water does not collect in the bottom of the hole and it saves a lot of tamping.
All of this is a whole lot more important if putting the posts in clay soil that doesn’t drain well compared to sand where the water just runs straight through. I have the sandy soil so I mainly just tamp them in well. One of things I remember from working with Grandpa was “tamp the bottom, the top will take care of itself.
Another thing I do is put a “cap” on top of the post to keep water from entering there. These are coffee cans generally because that is what I have that won’t rust. My wife hates them but if it keeps the rain out I like them. Sloping the top of the post so water cannot pool there is probably as good as covering.
Having said all of that: most of the “barn builders” around here are using a full pvc sleeve that the post sets in from the base to above the splash board. Since these are inside the building and water cannot penetrate the post of from the top, that should prevent any rot from occuring below grade. However for a fence or deck where the top of the post can get wet I don’t think they would work as well.
-- Steve ... determined to die working and believing that God is good!
View CampD's profile
CampD
1696 posts in 3542 days
#6 posted 08-05-2010 02:32 AM
Only time you use concrete to set a post is on the hinge side of a gate, helps to keep it ancorded, till it rots that is (like mentioned above). Go ahead and tar with gravel or stone at the bottom for drainage.
-- Doug...
TopamaxSurvivor
18316 posts in 3732 days
#7 posted 08-05-2010 03:43 AM
WE always soaked them in penta. Some have been in the ground for 60 years, but that is an arid climate.
View richgreer's profile
richgreer
4541 posts in 3131 days
#8 posted 08-05-2010 04:56 AM
Back on the farm we always had some barrels of used motor oil around. Before we put wooden fence posts into the ground we would take them to a barrel of oil and dip the ends in about 3 feet.
That was our standard practice as directed by my father and his father before him.
The logical question is “did it do any good?” and the honest answer is “I don’t know.” I can only attest that it was messy.
Tim_456
#9 posted 08-05-2010 05:20 AM
whoa, great advice! I’m going to cut the bottom on a bevel, slather it with tar, AND use the gravel; thanks for all the great tips! My two measly posts are going to out last everyone :D
View spclPatrolGroup's profile
spclPatrolGroup
233 posts in 2951 days
#10 posted 08-05-2010 05:59 AM
If you seal the boards, how will moisture get out? The wood will asorb moisture, above the tar, and probably wick it in behind the tar, if that happens, then the tar seal would be holding moisture in the post. I would pour concrete, have it come a few inches above the ground, then once it has cured, anhcor yoru post to it, they have little brackets that you anhcor to the concrete and then your posts bolt to those.
View swirt's profile
swirt
2814 posts in 3028 days
#11 posted 08-05-2010 05:57 PM
I’d go without the tar. I look at it like this way. When you cut a log down and store it to later turn to lumber, you have to get the bark off, because the bark seals the moisture in and lets the bugs and other organisms get to work.
Example: Hornbeam is a very hard wood, but if you cut a hornbeam tree down and leave the bark on, if you come back a year later, the wood will be pithy and useless.
By putting the tar on it you are essentially coating the timber with artificial bark. Tar is not the same as treating it with something that will completely penetrate and allow water to move in and out of the wood.
spclPatrolGroup
#12 posted 08-05-2010 08:57 PM
Also if you live within a city, I have never seen a city code that did not include a whold section dedicated to how to install support posts, so you may want to check that out if you think it effects you.
View Abbott's profile
Abbott
2570 posts in 3360 days
#13 posted 08-05-2010 10:39 PM
I coat the part of the post that will be in the ground with old motor oil, if I don’t have any around then I coat them with Thompsons Water Seal. Posts last without rot for many, many years that way. I bet tar would also work very well.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
View JoeM789's profile
JoeM789
1 post in 1132 days
#14 posted 06-16-2015 12:03 AM
That’s flawed logic. Bark isn’t waterproof. And it certainly does not protect the tree from air either. Not to mention that trees do last a helluva long time with the bark on. Nevertheless. The tar has proven itself to work time and again. You cannot and should not attempt to dispute what our ancestors already learned. The problem with today’s generation is that they would rather stake their claim to their own false wisdom instead of admitting that our great grandfathers knew better. I have seen more old buildings last longer than any modern ones.
I d go without the tar. I look at it like this way. When you cut a log down and store it to later turn to lumber, you have to get the bark off, because the bark seals the moisture in and lets the bugs and other organisms get to work.
- swirt
View Ghidrah's profile
Ghidrah
667 posts in 1278 days
#15 posted 06-16-2015 01:19 AM
In the “old days” it was creosote, they coated everything in contact with or near the soil. All the old wooden objects, bridges railroad ties, wood house and barn foundations were also creosoted. Back in 1977 I worked for the town and we remodeled 3 of the wooden bridges in town, It’s worse in the summer, everyone got burns from the off gassing from the old and new materials.
As for water pooling within the concrete, it isn’t entirely true, it has more to do with perk value of the soil, the lower the value the longer water remains suspended in the upper soil column. Any rocks etc, in the soil column moves around during the winter, house foundations, (block and mono) have been tarred for decades, when the winter comes and the soil moves, (heaves) it grinds against the tarring and can and does scrape it back to bare concrete. In the early to mid 80s as the foundations were backfilled many builders stuck 3/4” rigid foam at the frost line to add protection.
Treated lumber comes in a few types, CCA, ACQ, CA, SBX and MCQ, (may be related to different parts of the country) and a few grades, marine grade, no ground contact and in ground contact lumber. All wood rots, some slower than others, cypress was great, find that today, cedar, black locust and walnut.
Throw mason sand down and pack then 3/4” aggregate, mix a 60lb bag of quikcrete then set the post in and plumb. If your soil has lots of clay lighten it up with mason sand and compost, 1/2way fill the hole, tamp and flood, let perk and when clear fill the hole. Leave the plumb sticks in place a couple 3 days then remove.
-- I meant to do that!
showing 1 through 15 of 31 replies
