ROS to finish aluminum
Forum topic by Viktor posted 1017 days ago 821 views 0 times favorited 10 replies Add to Favorites Watch
View Viktor's profile
Viktor
467 posts in 1583 days
1017 days ago
Topic tags/keywords: question sander sanding
Has anyone used random orbit sander to sand/polish large aluminum surface? Are there any issues with heat buildup, aluminum dust clogging insides of the sander and filter etc? I believe aluminum dust is a fire hazard also. I have Bosch ROS20VSK.
10 replies so far
View Mark Shymanski's profile
Mark Shymanski
3960 posts in 1877 days
#1 posted 1017 days ago
I would imagine that aluminum being a metal might be a shorting hazard for the sander. How much material do you have to remove? If you are just buffing it up to make it shiny it may be worth looking at a car polisher or similar tool. Those sheepskin pads with a little rubbing/polishing compound should make short work of the job.
-- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2
Viktor
#2 posted 1017 days ago
Mark, good point about shorting. I want to put some shine on a table of a portable saw. It looks like it was done with 60 grit sandpaper at the factory, which makes it very non-slippery. I might just do it with sanding block by hand.
Mark Shymanski
#3 posted 1017 days ago
I ‘polished’ my TS table with some steel wool and elbow grease, it didn’t take long and made the table considerably more slippery. A bit of floor wax helps as well, although I find I have to repeat the waxing more often than I do for the cast iron tables I have, perhaps the aluminum is more porous?
View DeputyDawg's profile
DeputyDawg
160 posts in 2130 days
#4 posted 1017 days ago
Now your talking my language. I would think it all depends on what you are trying to polish. I would suggest you use a product called Wenol or Mother’s. You should be able to find them in any automotive store or the Wenol in a motorcycycle shop. I used Wenol and sold it in Arizona and there is none better. It is a chemical based polish with no abrasives in it. You can either use a soft cotton fabric like an old T-shirt or the polishing pad that comes with a car polisher. Look at any big truck with shinney wheels and you can see what it will do to a dull aluminum wheel
-- DeputyDawg
View Seth's profile
Seth
5 posts in 1025 days
#5 posted 1017 days ago
A quick look at the OSHA guidelines for aluminum state that “The National Fire Protection Association has assigned a flammability rating of 1 (slight fire hazard) to aluminum (dust or powder).” I’ve worked in a plant that generated a lot of aluminum shavings and they really weren’t concerned about fire hazards (and they had 50 gallon barrels of the stuff).
I would be worried about aluminum dust causing galvanic corrosion in your sander more than anything.
View TheWoodNerd's profile
TheWoodNerd
288 posts in 1356 days
#6 posted 1017 days ago
I think the shorting comment was directed more at damaging the ROS than a fire hazard. But offhand I would think these things would be pretty well sealed against dust to start with, not sure if it’s a realistic concern. If you’re just polishing up some aluminum, you’re generating some pretty minuscule amounts of incredibly fine powder.
-- The Wood Nerd -- http://www.workshopaholic.net
View patcollins's profile
patcollins
700 posts in 1030 days
#7 posted 1017 days ago
Wear a mask, you dont want that stuff clogging your lungs, unlike powdered wood your body will not break that down.
View Adam's profile
Adam
43 posts in 1318 days
#8 posted 1017 days ago
There are scotch brite type pads that are made for ROS. I found some at Lowes, I think McMaster sells them also.
Adam
TopamaxSurvivor
13192 posts in 1840 days
#9 posted 1017 days ago
When cutting Al, gauling is always a problem. I suppose it would be for sanding too. Probably clog up the paper pretty quick/
View FreshPants's profile
FreshPants
10 posts in 1257 days
#10 posted 1016 days ago
I’ve used a DeWalt (with dust collector box thing) RA sander on aluminum panels (not a really large surface. All was fine, leaving a pretty even swirly scratch pattern (although not as swirly as I was hoping for), and didn’t short out my sander.
