Does anyone know the best way to draw an Arch
Forum topic by Budd posted 08-04-2010 03:15 AM 1636 views 0 times favorited 12 replies Add to Favorites Watch
View Budd's profile
Budd
7 posts in 3053 days
08-04-2010 03:15 AM
I need to cut an decorative arch or curve in the support for a step stool; I guess they would be considered the rails in the project. I seem to remember one way of using string but I have not been able to make this work. Does anyone know the method or a better method?
Thank you
Bud
-- Bud Paddock
12 replies so far
View canadianchips's profile
canadianchips
2602 posts in 3117 days
#1 posted 08-04-2010 03:19 AM
A flat stick with a tiny nail in one end, drill a hole for your pencil in the other end,
View lew's profile
lew
12269 posts in 3875 days
#2 posted 08-04-2010 03:21 AM
I use a thin wooden strip with a string tied from one end to the other. As the string is pulled tighter, the strip bows. Then just use a pencil to draw along the strip. I know this “thingy” has a name but I’m not sure what it is!
View araldite's profile
araldite
188 posts in 3524 days
#3 posted 08-04-2010 03:37 AM
I’ve tapped in three nails, two at the bottom where I want the arch to end, and one at the apex. Then I just wrap a flexible wooden or plastic strip or a long flexible metal ruler over the top nail and hook it under the bottom two to form the arch. This gives something that conforms to the exact piece you’re working with. You can add additional nails to change the shape until you get something you like. Then trace it out with a pencil so the nail holes are on the line and cut out.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
16276 posts in 4338 days
#4 posted 08-04-2010 04:44 AM
Ditto what araldite said.
View mgb_2x's profile
mgb_2x
180 posts in 3189 days
#5 posted 08-04-2010 04:57 AM
The gateway arch in st louis is a inverted cantenary curve. As I recall the only way to get this shape is to suspend a steel chain between two points. Here is a link on making the shape. ?http://www.ehow.com/how_5024601_build-catenary-curve-arch.html?
-- "aim small miss small" m g breedlove
View BertFlores58's profile
BertFlores58
1698 posts in 3042 days
#6 posted 08-04-2010 06:27 AM
I think there is no room to find the center of the arc as it is now a step stool meaning irregular arc has to be done. You can use the process in making an ellipse. Connect both points where the arc should end – this become the major axis and the minor half axis will be set as you like depending on the string length and the two focal points which will be nailed in along the major axis. Note.. If the two focal points meet in the midpoint of the axis then it will create a circle.
-- Bert
View Budd's profile
Budd
#7 posted 08-05-2010 05:36 AM
Thank you all for all you information, this will help.
-- Bud Paddock
View Lucywu2012's profile
Lucywu2012
18 posts in 3012 days
#8 posted 08-05-2010 09:23 AM
Even though I can’t help you, I still want that you can solve your problem soon!
-- Lucy, China, Bamboo Art Designer, http://www.chinese-bamboo.com
View swirt's profile
swirt
3050 posts in 3092 days
#9 posted 08-05-2010 05:37 PM
Another option is to draw it on the computer (be sure to include horizontal and vertical reference lines) . Print it out, then draw with a pencil over the printed curve. Turn the page over so the pencil covered side is against the wood, then trace over the arch again. The pencil will usually transfer to the wood.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3600 days
#10 posted 08-05-2010 06:12 PM
I do it like araldite suggested.
-- Wayne - Plymouth MN
View Knothead62's profile
Knothead62
2584 posts in 3081 days
#11 posted 08-06-2010 12:31 AM
What lew described is a fairing stick.
View David Craig's profile
David Craig
2137 posts in 3229 days
#12 posted 08-06-2010 03:17 AM
Something you might want to look for in the future is a set of french curves. With a set of three, you can make a very large variety of shapes and sizes to plan out a figurative curve.
David
