Order of Finishing?? Or does it really matter??
Forum topic by handystanley posted 08-03-2010 08:31 PM 1103 views 0 times favorited 3 replies Add to Favorites Watch
View handystanley's profile
handystanley
169 posts in 3153 days
08-03-2010 08:31 PM
Topic tags/keywords: staining painting re-finishing douglas fir pocket door
I am in the process of finishing a pocket door that will be used between our master bedroom and bathroom. The door is made out of Douglas Fir.
On the bedroom side and the exposed edge the wood will be exposed. Therefore I am planning on staining it with a natural stain. The plan on the bathroom side of the door is to paint it because of the painted bead board in the bathroom.
So my question is, should I stain the two surfaces first and then paint the bathroom side of the door or should I paint first and then stain? Or does it not really matter? My concern is finish absorption / bleeding in the wood.
Any suggestions or comments would be helpful.
Thanks!!
-- "Projects beget projects and projects beget the need to buy new tools and that is what the cycle of life is all about." Stan Pearse, Novato, CA
3 replies so far
16281 posts in 4459 days
#1 posted 08-03-2010 08:44 PM
I guess you could argue either way. Personally, I’d stain and finish the bedroom side completely, then paint the other side. That way, you can be a little sloppy with the stain because the paint will cover it, and any paint that gets on the finished side should be easy enough to wipe off while it’s still wet.
View MyFathersSon's profile
MyFathersSon
180 posts in 3553 days
#2 posted 08-03-2010 09:07 PM
I’m with Charlie—that’s the way I’ve always done it in similar circumstances—and for the same reasons.
-- Those who insist it can't be done - should politely refrain from interrupting those who are doing it.
handystanley
#3 posted 08-03-2010 09:18 PM
Thanks to the both of you.
I had sent an email to Minwax early this morning with the same question and they replied the same way as you two idd. Stain first then paint.
