Soundproofing Shop Vac & Table Saw (acoustic panel vs insulation)
Forum topic by ambient posted 12-05-2016 01:58 PM 1022 views 0 times favorited 1 reply Add to Favorites Watch
View ambient's profile
1 post in 470 days
12-05-2016 01:58 PM
Topic tags/keywords: acoustic sound soundproofing table saw shop vac dampening loud quiet hearing
Hello guys and gals.
I am wanting to soundproof a shop vac and a table saw.
The shop vac will be placed in a box, similar to other builds that people have done with acoustic panel to lower the dB amount by building a noise reduction box.
The table saw will be done in a similar way. I plan to build a table saw workstation that will be surrounded on all 4 sides, similar to the shop vac. Both will have doors that open so I can get in and adjust settings and also change their underwear whenever needed. The only thing that will be exposed is the saw blade, which seems can’t be dampened by anything, so I’ll just have to deal with that.
Was wanting to know if anyone had any experience with insulation and doing these types of noise reduction boxes.
~My options were going to be
Acoustic panel: 1” Pyramid Foam ( 1×48”x72”x1” panel which can cover 24sq feet).
Owens Corning Insulation: ( 9”x15”x25’ which can cover 31sq feet).
The insulation is only $0.04 less per sq foot, but the insulation is 8” thicker.
Was curious what anyone’s thoughts on this were or other recommendations.
I plan to do caulking and all that to get a good seal and also build some type of barriers inside the boxes for the sound to have more of a distance to travel (with wood left overs).
I also seen a video on youtube about using towels. The test that was done shown that they can work pretty well and you can also find them cheap @ thriftstores/ETC places of this nature.
Thanks for any feedback.
1 reply so far
View Gentile's profile
301 posts in 1751 days
#1 posted 12-05-2016 03:08 PM
My saw is pretty quiet unless I’m cutting a board.
I had a Craftsman shop vacuum that screamed like a heavily loaded 747 on take off. I bought a Rigid shop vac, it’s a LOT quieter…
Why are you trying to keep things quiet?
If I’m going to do doing something that creates a lot of noise, I’ll wear ear muffs. Outside my shop is not to noisey, it’s insulated behind the drywall…
Either the Eggcrate foam or the Bat insulation you use, would collect a lot of dust unless you sealed it in somehow…
-- "I cut it twice and it's still too short"
