Kobalt Table Saw Height Adjuster Too Loose--HELP
Forum topic by Woodworkingwill posted 12-05-2016 01:58 PM 1210 views 0 times favorited 7 replies Add to Favorites Watch
View Woodworkingwill's profile
Woodworkingwill
1 post in 735 days
12-05-2016 01:58 PM
Topic tags/keywords: table saw kobalt height adjustment knob dado
Hello,
Yep, I bought a cheap table saw because I move every two years and didn’t want the movers to damage my Woodshop centerpiece. I’ve had a kobalt table saw from lowes for about 4 months, and it has worked awesome. Unfortunately I was doing some dado cuts and noticed the blade height adjuster began moving counterclockwise on its own as I cut boards. After fooling around with the handle and underneath the saw, I can’t figure out how to tighten the tension so it doesn’t move once I set the height. Does anyone have any suggestions on how to tighten the height adjustment so it stays set?
Thanks, will
7 replies so far
View WearyTraveler's profile
WearyTraveler
4 posts in 1136 days
#1 posted 12-06-2016 01:51 AM
I’ve got a porter cable from Lowes. Does the same thing. I’d be interested in any thoughts too… I posted a question about this and it seems that this is something that goes along without our “inexpensive ” saws… :(
runswithscissors
2892 posts in 2222 days
#2 posted 12-06-2016 04:50 AM
Do these saws not have a lock knob for the height adjustment?
View MrUnix's profile
MrUnix
7037 posts in 2396 days
#3 posted 12-06-2016 06:57 AM
I seem to remember that those saws only lock the bevel angle, not the blade height… unless I’m thinking about a different saw. If you can’t figure out why it’s moving (and fix it), then I guess you could always try using one of these universal blade height lock attachment thingies:
View BenjaminNY's profile
BenjaminNY
134 posts in 1599 days
#4 posted 12-06-2016 06:50 PM
Doesn’t matter if the saw cost 100 bucks or 1000. The blade elevation should not be moving when the saw is on. Call the company and see if there is a fix or return the saw. Lowes will take it back.
View Gandy836's profile
Gandy836
1 post in 117 days
#5 posted 08-14-2018 03:51 PM
What is the blade height locking thingamajig.having same problem my kobalt,thought i was going nuts. Will try calling Loews and see what they say.bought right before Xmas so its about 8 months old but did not save the box it came in. Had to hold knob while making dados and pushing eith the other. dangers I think. I have BT300 for back up.
View MrRon's profile
MrRon
5189 posts in 3440 days
#6 posted 08-14-2018 04:03 PM
I don’t know if this is the problem, but when you set the height of the blade, do you raise the blade and then lower it to the right height, or do you raise the blade to it’s correct height ? When you lower the blade, you introduce slack in the rack mechanism. When you raise the blade, there is no slack in the mechanism.
View smitdog's profile
smitdog
410 posts in 2302 days
#7 posted 08-14-2018 04:36 PM
+1 for what MrRon said – always raise the blade to the correct height. If the blade is still falling after that then there is something mechanically wrong. In a pinch maybe you could use a clamp to physically restrict the handle from being able to turn until you get a permanent solution figured out?
-- Jarrett - Mount Vernon, Ohio
