fresh cut wood
Forum topic by supervato posted 08-02-2010 09:59 PM 3052 views 0 times favorited 13 replies Add to Favorites Watch
View supervato's profile
supervato
153 posts in 2835 days
08-02-2010 09:59 PM
Topic tags/keywords: question
Hey everybody, does anybody know how long i have to waite before i can use cut wood to break down into useable lumber. I have some black walnut and hickory tree logs that my friend gave me. Some i will cut down to 8/4 stock and some I will use as 3×3 turning blanks. But do i have to wait to mill them or can I mill them then wait and let them dry out. Or do i have to wait at all?
13 replies so far
View Div's profile
Div
1653 posts in 2846 days
#1 posted 08-02-2010 10:28 PM
Mill them while the logs are green and then you dry. Only problem is you will have to wait a couple of years to airdry 8/4 stock!
-- Div @ the bottom end of Africa. "A woodworker's sharpest tool should be his mind."
View tnwood's profile
tnwood
255 posts in 2992 days
#2 posted 08-02-2010 10:30 PM
Coat all the ends of the log with Anchor Seal or latex paint now. Mill the logs as soon as possible. If you have to store the logs, get them off the ground and away any moisture. Sticker the boards as soon as they are cut. The length of time before they are dry enough to use depends on where you store them, air flow over them, ambient humidity and temperatures, sticker details, etc. Either buy or borrow a moisture meter to monitor the stack and see what happens. Typically I would say 6 months for 8/4 stock and probably a year for 12/4 but it depends on too many things to predict.
View Catspaw's profile
Catspaw
236 posts in 3721 days
#3 posted 08-02-2010 11:08 PM
1” = 1 year for passive air drying. Don’t mill them at all. Cut them as your 8 or 4/4 rough lumber and dry them first. If you mill them now they will be subject to many changes. Then all your milling will be for naught.
There’s no point in painting the ends if you’re going to slab them up into lumber right away. Painting is only for storing the logs. Once they are slabbed up and you expose large surface area, painting the ends serves no purpose.
-- arborial reconfiguration specialist
View richgreer's profile
richgreer
4541 posts in 2980 days
#4 posted 08-02-2010 11:32 PM
I’ve always heard you need to air dry 1 year plus 1 year per inch (i.e. 2 years for 4/4, 3 years for 8/4, etc.)
supervato
#5 posted 08-03-2010 12:19 AM
ok that definitly helps i wanted to get them to rough slab for easier storage.
Catspaw
#6 posted 08-03-2010 01:01 PM
Well, the 1 and 1 is general of course. It depends on the wood and the climate. Beech will take forever and poplar will dry fast. Arizona will dry fast, Alaska, well, maybe forever. ha! Hence the moisture meter to monitor its progress.
BTW, Kiln drying (maybe ask the sawyer) is not necessarily expensive and sure beats waiting a year or so to use your bounty. Remember, the price of your own lumber could/should be alot cheaper than paying at the big box store.
View Nomad62's profile
Nomad62
726 posts in 2864 days
#7 posted 08-03-2010 07:22 PM
I’ve been reading several threads stating the 1” per year air dry thing is a wives tale, others swear by it; I tend to believe it has more to its drying environment than such a mechanical statement can justify. I recommend slicing the lumber as you wish to make it and Anchorsealing (or other product made for the use) the end grain as soon as possible. Catspaws last post seems the best advice of the above. Keep an eye for bug holes or activity, if you find any have the wood kiln dried asap to off the little boogers.
View Richard 's profile
Richard
394 posts in 3027 days
#8 posted 08-03-2010 09:20 PM
I have a sawyer who mills logs for me and I sticker and airdry them for about 6 months before I use them. Of course Idaho summers are dry and hot and the logs that are sawn up have been siiting in my sawyer’s yard for a couple of months (not exactly freshly green).
I say mill them to the thickness that you want but I wouldn’t put any more work into your green boards other than stickering them level and sealing the ends. After they have mostly dried you will find your share of cracked and warped stock, but also some decent stock lumber. I would then put more effort into resizing your decent lumber into the dimensions you want. Also free craigslist latex paint will do for sealing the ends of the boards. I also take a few pictures of the boards in raw log form and pictures of the boards drying. I usually include these when I give the final projects made from the lumber to the new owner.
-- Richard Boise, Idaho
supervato
#9 posted 08-04-2010 05:23 AM
thank you everybody
View edwin111's profile
edwin111
1 post in 2711 days
#10 posted 09-21-2010 09:37 AM
Nice post.
-- EDWIN
View PBthecat's profile
PBthecat
53 posts in 2956 days
#11 posted 09-24-2010 07:52 PM
I’d wait for as long as it took me to purchase a moisture meter…
http://www.electrophysics.on.ca/e_index.htm
-- "Every hundred years, all new people"
View Sawmillnc's profile
Sawmillnc
150 posts in 2960 days
#12 posted 09-27-2010 05:42 AM
I am here to tell you the 1” per year stuff is bunk and I wish this tale would just go away.
Dr Wengert at Madison will tell you otherwise as will the USDA documentation on air drying and kiln drying.
You can effectively air dry Red Oak or White Oak in average temps above 70 degrees in less than 4 months.
I dry thousands of BF of wood ( walnut, oak, cedar, pine etc) and none take that long.
8/4 stock can take upwards to a year or year and a half at most depending upon where you dry and stack.
-- Kyle Edwards, http://www.sawmillnc.com, Iron Station , NC (near Charlotte)
View millmgr's profile
millmgr
27 posts in 3018 days
#13 posted 09-27-2010 07:28 PM
It’s not so much a time issue as moisture content . Depending on the intended usage, you may be able to make something like a table leg out of well air dried stock, but need kiln dried for furniture, cabinets, doors etc. that will be fastened to kiln dried stock or plywood. There should be some local woodshop or mill with a kiln that will put your boards in with a load that dries on the same schedule and then you don’t have to worry about it.
