Can someone shed some light on this circular saw technique?
Forum topic by Derrick posted 12-05-2016 02:23 AM 934 views 0 times favorited 11 replies Add to Favorites Watch
View Derrick's profile
Derrick
84 posts in 1259 days
12-05-2016 02:23 AM
https://youtu.be/JkDYR7oUxt0
I don’t remember how I found this video, but I think it’s fairly entertaining. At around the 2:30 mark he pushes the saw sideways. I’ve just never seen a circular saw used like that.
Has anyone used this technique before? If so, would you care to explain what’s all going on?
I can’t think of any projects where I’d use this, it just seemed interesting.
Thank you.
Derrick
11 replies so far
View waho6o9's profile
waho6o9
8362 posts in 2697 days
#1 posted 12-05-2016 02:40 AM
It’s similar to cutting a cove on a table saw.
http://woodgears.ca/cove/index.html
Not something I’d do as the teeth aren’t designed to cut with sideways pressure.
View toolie's profile
toolie
2143 posts in 2749 days
#2 posted 12-05-2016 03:34 AM
Thats been done with radial arm saws. More importantly, he needs a new dust mask.
View bigJohninvegas's profile
bigJohninvegas
484 posts in 1582 days
#3 posted 12-05-2016 03:34 AM
Can’t say that I have seen a hand held saw cut a cove before. Pretty cool.
I have seen it done on a table saw several times. I like the router work too.
I have a router sled I use to flatten large boards, but never thought of using it the way he did.
-- John
TopamaxSurvivor
18358 posts in 3796 days
#4 posted 12-05-2016 06:08 AM
Probably a bit hard on the saw and blades ;-)
View Gene Howe's profile
Gene Howe
10840 posts in 3549 days
#5 posted 12-05-2016 11:37 AM
As whao6o9 said, same as coving on rhe TS. I can almost guarantee he didn’t get that depth in one pass.
I usually do it in 1/16” increments. At that depth, the blade is in no danger.
View Holt's profile
Holt
272 posts in 2749 days
#6 posted 12-05-2016 01:35 PM
I bet the saws “arbor” bearings take a beating…
-- ...Specialization is for insects.
View canadianchips's profile
canadianchips
2602 posts in 3117 days
#7 posted 12-05-2016 01:51 PM
As “Gene” said…..multiple passes with 1/16 or 1/8” cut…..depending on blade and how sharp. I use a rip tooth blade . I ‘ve cleaned out lap joints with this method as well. I prefer using table saw for these cuts !
View Gentile's profile
Gentile
308 posts in 1939 days
#8 posted 12-05-2016 03:22 PM
I started coughing while watching the video, so much dust in the air
-- "I cut it twice and it's still too short"
Gene Howe
#9 posted 12-06-2016 12:29 PM
- Holt
Not if you’re patient.
View Bill White's profile
Bill White
5054 posts in 4081 days
#10 posted 12-06-2016 01:47 PM
Had to quit the vid. The “music” was makin’ me nutso.
Bill
-- bill@magraphics.us
Derrick
#11 posted 12-06-2016 01:57 PM
Thanks s for all the info! It just seemed like a cool process.
