Best Lights For New Shop?
Forum topic by rustynails posted 12-04-2016 11:18 PM 1489 views 0 times favorited 32 replies Add to Favorites Watch
View rustynails's profile (online now)
rustynails
812 posts in 2769 days
12-04-2016 11:18 PM
We just purchased a new property on the lake which will eventually be our retirement home. The property has a newer 1200 sq.ft. pole barn with 10 ft ceilings that I am currently insulating and starting to ruff in for electrical. I am trying to get the barn ready this winter as the house will need a lot of work and we plan on starting that in the spring. My current shop has 4ft florescent fixtures. (T-12’s/ old school). What is every one using these days for their shops? I am looking for something that is energy efficient but still is cost effective.
Thanks
32 replies so far
View Kelly's profile
Kelly
2187 posts in 3184 days
#1 posted 12-04-2016 11:42 PM
I’m switching out to four foot LED’s I picked up at Costco, since they were the same price or cheaper than florescent lights. So far, I have about ten or twelve and about fifteen more to go.
All my machines (band saw, drill press, polisher, grinders, etc. ) are now LED’s.
I had been running four foot plasma devices (florescents) because everyone had them and they could be packed in the car on the hour trips to town. Since going to eight foot LED’s would break the bank, I stayed with the four foot with them too.
It’s nice coming out to a cold shop and not having to deal with flickering lights.
View mrbob's profile
mrbob
182 posts in 809 days
#2 posted 12-04-2016 11:55 PM
LEDs, but do not get “cool light” spectrum over your finishing area, get “warm/sunlight spectrum” for there other wise you finishing/dye/stain will not look the same in natural light.
I just bought 2, 48” LEDs bright as heck.
View JAAune's profile
JAAune
1854 posts in 2557 days
#3 posted 12-05-2016 12:03 AM
If I’m not mistaken, daylight spectrum bulbs are considered cool (around 5500K or so). CRI is an important quality as well and low CRI bulbs may cast off an odd-colored light.
If high quality lights are too expensive to outfit the entire shop with them, consider using a few fixtures in the location that will be used for finishing.
View bigJohninvegas's profile
bigJohninvegas
545 posts in 1702 days
#4 posted 12-05-2016 12:47 AM
I have a 3 car size garage/shop that has 3-8’ fixtures that use 4-4’ bulbs in each fixture, with 4000k T8 bulbs. It’s not quite enough light. I have not switched to LED yet. A friend has the same fixture as me that has been retro fitted for LED. I think they are 6000k bulbs, and I thought they would be to much. However now that I have seen them in action, I will be going to them myself.
-- John
View Carloz's profile
Carloz
1147 posts in 832 days
#5 posted 12-05-2016 02:00 AM
- mrbob
Daylight is 5500k or 6500k which is equal to cool LED lights. Warm light is about 2700k and resembles incandescent bulbs. So on contrary you should use cool lights in the finishing area.
View dclark1943's profile
dclark1943
270 posts in 2428 days
#6 posted 12-05-2016 03:28 AM
Hello Rustynails ! I just converted my shop to LED’s. I purchased “LED2 Lighting” bulbs that go into the 4 foot florescent fixtures – - just throw out the ballasts, use the same tombstones, and direct wire them. They are 5000K with a CRI of >80. the Light is “Bright as heck” as Carloz said! These bulbs cost me $12.84 per tube. But – they are brighter, cooler, quieter and cheaper to run then florescents. I’m definitely glad I made the change. Here is the website of the company that makes them: http://www.led2.com/ Hope this info helps – - Happy Holidays
-- Dave, Kansas City
woodbutcherbynight
5837 posts in 2649 days
#7 posted 12-05-2016 04:54 AM
I am with the LED crowd, converted two units this spring and have been pleased with the results.
When you do your install wire an outlet to every light. Then you only have to wire the light on the ground and install it and just plug it in. Makes mounting alot easier and no need to be on a ladder fooling with hardwiring the unit. Nice bonus is if you have to change it you have only to unplug it. Or if you add something else you have a spare outlet.
View bdresch's profile
bdresch
151 posts in 1848 days
#8 posted 12-05-2016 05:04 AM
rather than the plug in variety I would buy cheap T8 4’ 2 bulb hardwire fixtures and use the retrofit bulbs. The all in one plug in variety like Costco sells are basically disposable. If you buy a real hardwired fixture you can replace the bulbs as technology gets better or if you have a bulb fail. If you have a Menards near you they have 10 packs of Sylvania 4’ LED on sale for around $60. If you pair that with the $22 direct wire fixtures you are at under $35 per fixture.
TopamaxSurvivor
18425 posts in 3916 days
#9 posted 12-05-2016 06:05 AM
Florescent are being phased out. Go LED. Conversion kits in the future are not a good option when the lamps are all gone. You have the opportunity to get ahead of the curve now ;-)
mrbob
#10 posted 12-05-2016 06:16 AM
Just buy LEDs forget the retro fits. Keep life simple and easy.
View Ripper70's profile
Ripper70
1196 posts in 1149 days
#11 posted 12-05-2016 06:33 AM
+1 for the Costco LED shop lights.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View SweetTea's profile
SweetTea
377 posts in 900 days
#12 posted 12-05-2016 10:27 AM
I have the 4 foot fluorescent fixtures that I purchased from Wal-Mary for $11 each. They run the typical fluorescent bulbs. What would be required to convert them to LED? Can I just purchase some LED bulbs and simply install them in place of my fluorescent bulbs? Or does something need modified?
Mine are not hard wired in, they are simply plugged into the nearest outlet.
View Dave Polaschek's profile (online now)
Dave Polaschek
3090 posts in 822 days
#13 posted 12-05-2016 11:36 AM
I’ve been using the Feit corn-cob LEDs in standard (screw in) light fixtures. A 40W warm white LED (not 40w equivalent, but actually draws 40w) puts out 4000 lumens, and two of those eight feet apart light up my shop very nicely.
-- Dave - Minneapolis
View hig789's profile
hig789
39 posts in 1081 days
#14 posted 12-05-2016 12:13 PM
I have been debating switching to leds also from my t8 fixtures. The only thing I really don’t like about leds is that unless you get quit a few of them you can get a really bad shadowing effect. Now I don’t have experience with the 4’ fixtures though, I’m just going by the fixtures n our house and the ones on my saltwater aquarium. I’m sure the 4’ fixtures will put out a nice wide spread of light. Just something I thought I’d mention.
View Holt's profile
Holt
280 posts in 2869 days
#15 posted 12-05-2016 01:25 PM
I changed ballasts and converted to T8 for my last shop. Since moving, when I eventually get to the shop on my to-do list. my plan is to go with LED lighting. Assuming my time is worth something and the way the prices have been moving, it may turn out to be cheaper!
-- ...Specialization is for insects.
showing 1 through 15 of 32 replies
